11-17-2012, 08:04 PM | #1 |
Do I need a Puller or tie rod separator?
Going to replace manual with power steering. I need to remove the end of the pitman arm that is not attached to the gear box. Will a tie rod separator do the job or do I neeed a puller?
Posted via Mobile Device Posted via Mobile Device |
11-17-2012, 08:31 PM | #2 |
Re: Do I need a Puller or tie rod separator?
I use a pickle fork. I cheat, though, because my pickle fork is on an air chisel.
11-17-2012, 08:55 PM | #3 | |
Jeff 1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt 1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior |
11-18-2012, 01:28 AM | #4 |
Before you go to the trouble be sure that arm is the same for power vs non power. I always use a puller but heat the arm around the sahft with a toruch first. Of course you run the risk of burning up the seals on the old box, but if it is going in the scrap pile anyway, who cares?
11-18-2012, 08:05 AM | #5 | |
Watch out for your cornhole !
11-18-2012, 07:10 AM | #6 |
I loosen the bolt almost all the way. Then a sharp thwak with a mini sledge. No problem. I have a real nice Snap-On pickle fork but it never gets used.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
