![]() Join Date: Aug 2008
72 Big Block swap parts almost everything you need to install a BBC
I started accumulating parts to swap a big block into my 71 GMC but sold the truck, and now I need funds to put the big block into a 79 Malibu instead. Most of the parts came from here on the board.
Shipping to lower 48 is included in prices Here is what I have: 72 (only) big block alternator brackets, 3 pcs and most if not all hardware SOLD 72 (only) engine mount frame brackets, biscuits and clamshells along with frame bolts and motor mount bolts SOLD Newer 4 row brass and copper radiator, holds water, came from a running truck $150 Original 4 row brass and copper 4 row holds water, came from a running truck as well, is noticeably heavier than previous radiator. There is one tube that is bent but not leaking. SOLD 4 row radiator hold downs and bottom mounts [B]SOLD Big block 4 row fan shroud no cracks or breaks SOLD Pair of lower fan shroud retaining clips SOLD Big block power steering pump, brackets, pressure and return lines, remote resevoir with cap and hose SOLD 7 blade big block AC clutch fan $50 Oil pressure gauge line with correct adapter to screw into block SOLD Power brake booster steel vacuum line and hose. SOLD 3 pc pulley set for truck with AC. The lower pulleys are two peices for a total of 3 grooves. The upper pulley has two grooves. SOLD 72 V8 throttle cable, return spring and mounting bracket $30 V8 wiring harnesses. I was told this was off of a big block truck but have not verified. One has only one wire cut (yellow) $50 V8 wiring harnesses. I was told this was off of a big block truck but have not verified. Has a few wires cut and the tape has been unwrapped $30 New in box rebuilt and primed big block short water pump to work with above mentioned pulleys and brackets SOLD I do not have the A/C brackets as the truck this was going to go in did not have factory A/C and I planned to install aftermarket A/C if I got that far. I also do not have the heavier front coil springs required for a big block. The total for all parts listed separately is $1,375. I will take $1100 for all of it, or $1000 if you only want one radiator (you pick which one) Prices include shipping to lower 48 Please do not send PM's. Keep the inquiries in the thread. I want to try and sell this all together to simplify things but if you want to put yourself inline for individual pieces please do so. As soon as it is apparent in the thread that I can part this out, I will do so. Last edited by WIDESIDE72; 12-05-2012 at 06:59 PM. |
Re: 72 Big Block swap parts almost everything you need to install a BBC
oem radiator
hold downs shroud Last edited by WIDESIDE72; 11-18-2012 at 12:46 AM. |
shroud ears close up
power steering pump and brackets clutch fan Last edited by WIDESIDE72; 11-18-2012 at 12:44 AM. |
even more photos
oil pressure line
power brake vacuum line pulleys throttle cable |
wiring harnesses
water pump lower shroud clips |
I am interested in the following items, would you take $160 for these items?
4 row radiator hold downs and bottom mounts $30 Big block 4 row fan shroud no cracks or breaks $125 Pair of lower fan shroud retaining clips $20
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
#8 | |
Posted via Mobile Device |
Post pics of Malibu please! Love those old malibu's
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently. http://67-72chevytrucks.com/vboard/s...d.php?t=451950 1971 c10 step 250 3 OTT 1969 c30 TOW-MATER. 307 4 speed, holmes 440 body. http://67-72chevytrucks.com/vboard/s...d.php?t=451082 2006 CTS-V LS2 6spd. |
#10 | |
![]() Join Date: Sep 2007
Would like to be first in line for the following items: Alternator bracket 1972 only,oil pressure line, power brake booster line, oem radiator, 4 row hold down brackets. On the oem radiator does it say "harrison" on the top by the fill hole? Please let me price and shipping to 97050, can you make a package deal on all these items? Thanks Mike
#12 | |
I will check but I believe I did see the Harrison tag on the radiator
Sounds good. If it does say Harrison on the radiator than I'll take it. If not I"ll have to past only on that item. I'll take everything else I requested. Thanks Mike.
#15 |
#16 |
I'm interested in the 72 only big block stands and clams.
OLDIRONRACING |
#17 |
#18 |
O.K. sounds good. I'll take it, along with the other parts when your ready to sell. Mike.
#19 |
#20 |
Still a lot of pieces not spoken for
Posted via Mobile Device Last edited by WIDESIDE72; 11-26-2012 at 01:00 AM. |
#21 |
It looks like this will get split up. PM's sent to everyone in line.
#22 |
72 big block frame mounts and clamshells still available. Oldironracing sent me a pm that he will pass on them.
#23 |
Payment sent for these items.
#24 |
#25 |
There are still some good parts available. 72 motor mounts/ clams not yet spoken for.
