Seat Swap
Will a bench seat from 73-87 fit in a 67-72?
Re: Seat Swap
![]() Join Date: Oct 2012
Re: Seat Swap
I'm very new to these trucks, so take this with a grain of salt.....but all the reading I did on the subject (probably a weeks worth at least) said that the only seats that are true bolt in are the 67-72 seats, but that the 73-87 seats front bolt holes line up and only the rear holes need to be drilled. Can't promise that is true, but thought I would throw it out there since you've gone a day without a reply.
1969 Chevy C10 SWB Fleet - Build thread > http://67-72chevytrucks.com/vboard/s...d.php?t=593554 2008 GMC Sierra Denali - 6.2L AWD - my daily 2011 Ford Flex Limited - Ecoboost AWD - wife's daily 1987 Buick Regal Turbo T - 63K miles - Strip/Street car 1965 Ford Mustang Coupe - 289, c4, 53K miles |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Re: Seat Swap
I believe that is what is in my truck. The seat was in the truck in 2001 when I bought it and i'm sure it had been recovered and not very well because I've only put 5000 miles on the truck since I bought it and the seat material is split and l
and I'm only 220.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
![]() Join Date: Sep 2009
Re: Seat Swap
The floor of a 73-87 is completely different. I beleive the 67-72 seat brackets will bolt to the 73-87 seat though.
Re: Seat Swap
The seat in the pic from the member poster Alredy Gone it is a seat out of a early to mid 80's truck and the steering wheel is a S-10 from 83-85. The last one was for free!! [so was the first one as far as that goes] Jim
Re: Seat Swap
if you have a welder your darn skippy they can fit
1969 Custom 30 wrecker
Re: Seat Swap
My 69 stepside has a mid 70's GMC bench in it and I can say you will have to drill holes as the mounts don't line up. The PO also made 3 inch risers for each location. Not sure if that's absolutely needed or not though.
I'm returning it to the correct seat soon. ![]()
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
Re: Seat Swap
I just need a seat that folds. I understand that 67 & 68s fold as do everything after 1972.
