11-20-2012, 03:29 PM | #1 |
column issue
i have a 70 with a non tilting column, and i have some issues... my shifter (th350 on the column) is stiff into park, and sometimes wont go below Drive... any ideas?
70 C10 working on a LSx swap 4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol |
11-20-2012, 04:31 PM | #2 |
Re: column issue
if you disconnect it from the transmission, will it do the same thing? will the transmission shift fine disconnected?
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
11-20-2012, 04:57 PM | #3 |
Re: column issue
40 year old moving parts respond well to cleaning and lubrication
11-20-2012, 05:10 PM | #4 |
Re: column issue
well the column is fine when unhooked and the tranny is pretty easy to shift when its not hooked to the column
11-20-2012, 05:11 PM | #5 |
Re: column issue
i dont think its a lube issue... i was thinking that a bushing in the column may be bad?
11-20-2012, 05:47 PM | #6 |
Re: column issue
could be, could also be the linkages getting into a bind somehow
