11-23-2012, 09:39 PM | #1 |
Suburban rear floor
Hello can any body recommend the best way to replace the plywood floor in a 1970 burb.? Is it a body off frame deal or just unbolt everything and lift the body up and slide the plywood under the rails? Thanks for any info.
Posted via Mobile Device |
11-23-2012, 09:51 PM | #2 |
What?
Re: Suburban rear floor
Actually you can take the wood out while body on frame, but 40 some odd years of elements attacking the wood and metal supports; it becomes one with the body and chassis.
In my case I had to cut my floor out, but putting it back in was rather easy all things considered. The floor is actually two pieces. There is a small tongue and groove piece in front of the passenger side wheel well, and you are to remove that by sliding it rearward and then remove the spare tire tub. Once you do that, slide the main wood floor to the passenger side. If you manage to do those things, you can then lift the floor out from the inside and out the rear. Installing the new wood floor is just the reverse of that process. Try to take the old floor out in the biggest piece you can, then that way you can lay it onto the new wood and use it for a template for all the holes for the carriage bolts.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
11-24-2012, 01:04 PM | #3 |
Hey thanks Chris after I read your info went back to the garage and looked it over. Sprayed all the carriage bolts with some WD40 and started to attempt the removal on the wheel well ones first three came off the rest saws all them. Not looking forward to the one up in side the rails. Did you replace your with a marine plywood or did you use a treated on or ?
Thanks again Posted via Mobile Device |
11-24-2012, 02:45 PM | #4 |
What?
Getting the bolts out is a challenge, but they are low grade steel type.
Most of them I didn't even bother trying to tackle with a socket wrench, I would just get a good grip on the nut with a pair of vise grips and bend back and fourth till it snapped off (The wood floor would give enough to allow room to flex). I used marine grade wood, then primed and painted both sides. The under side I brush painted on a liberal coat of paint, more so than the interior side just for added protection from the elements.
Chris 1968 K20 Suburban 1972 K10 LWB PU Last edited by vectorit; 11-25-2012 at 01:05 AM. |
11-24-2012, 07:55 PM | #5 |
Thanks Chris grabbing the bolts with vise grips and working them back in forth worked good. I will check on marine plywood next week.
11-26-2012, 01:29 AM | #6 |
Well couple more broken saws all blades and a lot of working back inforth to break the bolts off, the floor Is out in one piece, ended up taken the wheel well out, not by choice they where rusted out didn't see that before they where covered up with carpet, it sure did help taken the plywood out.
11-26-2012, 01:43 AM | #7 |
What?
WOW! you sure kicked butt on getting that floor out.
So you got the floor out in one piece huh? Lucky you
11-26-2012, 01:52 AM | #8 |
Yeah I was surprised too beings you said you had to cut yours in pieces I didn't know what to expect but breaking the bolts off went way faster. I am going to take out the spare tire well and I was thinking of taken two sheets of plywood T&G and putting the seem down the middle so that I can go all they way across.
11-26-2012, 01:58 AM | #9 |
What?
Glad the idea of busting the bolts off worked for you.
I remember when I did mine, I had a whole cup full of busted bolts when I finished. Don't pitch that original floor until you use it to trace out the bolt holes, and the outline of the original floor.
12-09-2012, 04:59 PM | #10 |
im in the process of building a raised steel floor in the back of mine...
04-07-2013, 06:44 PM | #11 |
Southern Nevada Coal Roller
looks good. I am thinking about replacing my rear wood with metal so I can anchor in a newer generation 3rd row rear seat better. If I can find a suburban in the junk yard I will cut out the back and graft into the suburban
Chris
Chris 72 Suburban, 1 ton dodge chassis 4wd cummins, DTT 47rh 89%, PDR VE 3200 spring, PODS, Piers Turbo. 36 Chevy P/U rat rod project. 4bta cummins |
04-08-2013, 02:13 PM | #12 |
Rockcrln put a newer modle Yukon floor in one with the pockets for a removable rear seat. It can be done.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
04-08-2013, 08:13 PM | #13 |
This is my plan as well but I am looking at either using a sheet of 14 ga steel that I have laying around or get a descent used long bed floor and modify that to fit.
04-09-2013, 10:34 PM | #14 |
i would say use the floor from a 69-72 Blazer and weld in the pockets for the 3rd row seat from a 73-91 model burb. be really good for those wanting the restored look as the seats from the two generations are about the same so you could adapt the upholstery.
04-15-2013, 07:09 PM | #15 | |
Chris
04-17-2013, 01:45 AM | #16 |
Still plays with trucks
What about doing the rear wood like some of the trucks with metal strips and dimensional lumber for the bed wood instead of plywood?
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
04-17-2013, 12:56 PM | #17 | |
I have been kicking around the idea of replacing my wood with quarter sawn oak. The only problem is that I am adding a third seat so 1/2 of it would be covered by a seat. If I do it (which will be very soon since I am in the process of restoring my 70), I will do a write up on it. |
01-02-2014, 08:34 PM | #18 |
I know this thread is old, but did anybody ever put a truck bed floor in place of the wood? That's what I'm in the process of doing, just curious about what it might look like.
-Holden 1983 & 1972 Chevy Longbeds (16) 67-72s (Rollback, 402's, Sierra Grande, Shortbeds, Shortsteps, Longhorn, etc) 1968 GMC Suburban- (Current project) Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=569806 (6) 60-66s (shortstep, rollback, two-ton, longbeds) (3) 47-59s half tons + MANY more and always looking for more |
01-02-2014, 10:52 PM | #19 |
it would look similar to the Blazer. and the nice thing is you could weld in the pockets from an 80's Suburban and have a quick fold\remove seat that could even be upholstered to match the original interior (if you like the factory appearance like i do).
07-24-2015, 01:00 PM | #20 |
Also was wondering, what size plywood did you guys use to replace the floor?
07-24-2015, 08:13 PM | #21 | |
07-30-2015, 04:58 PM | #22 |
Here's a link that may (or may not) be useful:
http://67-72chevytrucks.com/vboard/s...=574056&page=2
56 Chevy step-side 68 Chevy Suburban 69 Corvette Stingray 00 BMW 325 (Daily driver) 09 BMW M3 18 GMC Acadia (Wife's daily driver) |
01-03-2014, 01:17 AM | #23 |
I replaced mine with the floor out of a 2005 Yukon XL. It was a big pain in the buttocks but well worth the work. All of the seats from the Yukon fit like a glove now. The floor modification requires frame modificatin as well. You can look at the link for my 70 burban to see what we did. I can also take some more photos.
Silver Creek Auto Body & Detailing My 70 Chevy Suburban build: http://67-72chevytrucks.com/vboard/s...=574056&page=3 |
01-03-2014, 02:01 PM | #24 |
I decided not to use the truck bed floor as the wheel well holes are larger than the suburban. It would require sectioning length wise, I am not that good of a welder. Replaced it with marine grade plywood that was a little thicker than the original piece. Fortunately one of my best friends is a carpenter and he cut, drilled and routed until it fit perfectly. He copied the 2 pieces exactly and put it back together like the factory with the small "key" at the right front. Before I reinstalled it I primed with boat primer.
01-03-2014, 02:10 PM | #25 |
I sealed every thing with body seam sealer. Had the braces powder coated. Then covered the bottom of the floor with bed liner the same color as the paint. I found a product called UPOL Rapter that is tintable in any color. I covered from the pinch weld at the front lower edge of the fire wall to the rear. It took of the bed liner kits. This is a 4 wheel drive that will get dirty so I wanted easy to clean.
