Old 11-23-2012, 11:23 PM   #1
DoubleL
DoubleL's Avatar
Octane rating for 292?
I have been having some rattling under load that sure sounds like low octane. What do you guys run in your I-6's?
My 1965 C-20 project
https://67-72chevytrucks.com/vboard/...d.php?t=835095
DoubleL is offline   Reply With Quote
Old 11-23-2012, 11:33 PM   #2
donthekawguy
donthekawguy's Avatar
Re: Octane rating for 292?
Could also be timing. Octane stuff usually is high compression stuff, like if you were running a 12/1 motor you would need a higher octane. I'm sure someone out there knows a lot more about this than I do.
66 shorty
donthekawguy is offline   Reply With Quote
Old 11-24-2012, 01:17 AM   #3
pestwagon
CR is 8:1 or so , so regular gas is plenty for that motor. You probably have a non working vacuum advance and have it too advanced...
pestwagon is offline   Reply With Quote
Old 11-25-2012, 11:37 PM   #4
luvbowties
luvbowties's Avatar
Exclamation Re: Octane rating for 292?
...and it can quickly burn holes in piston tops...
luvbowties is offline   Reply With Quote
Old 11-27-2012, 09:06 PM   #5
DoubleL
DoubleL's Avatar
As of today I have retired my truck from DD service. I opened up my distributor and the vaccum advance looks rusty to me. It wasn't new when I got it. I think I am going to look at that as a possible cause. I am glad I don't have the pressure of using it for my main transportation anymore.
Old 11-27-2012, 11:28 PM   #6
j.kirn
all you have to do to determine if the vacuum advance is working is look under hood while engine is running and crack the throttle open while looking at the vacuum advance and you should see it moving
j.kirn is offline   Reply With Quote
Old 11-27-2012, 11:30 PM   #7
DoubleL
DoubleL's Avatar
Isn't the vacuum advance under the distributor cap?
Old 11-28-2012, 08:19 AM   #8
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Arrow Re: Octane rating for 292?
http://www.hotsixes.com/index.php?op...&id=2&Itemid=3
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 11-28-2012, 08:57 AM   #9
1963c-10
1963c-10's Avatar
Vacuum advance hangs out under the base of the distributer where the cap mounts. You should see the vacuum line running into it.
1964 Short bed trailer
