1992 gmc rally/vandura as donor?
Ben reading a while but never posted. This 92 gmc van is priced pretty fair and I was wondering if this would be a good donor vehicle to upgrade my 66 swb fleet side? Not worried much about the brakes since im doing lowered spindles and everything new as far as brakes are concerned! Ive read about the power box being backwards as well! I know this has been beaten to death but it seems that 2wd suburbans of the proper year are almost imposable to come by around here and I want the best donor vehicle to steal everything from for my old truck. Thanks!
![]() Join Date: Aug 2004
Re: 1992 gmc rally/vandura as donor?
any c10 truck from 71 up to 87 suburban or 2wd FS blazer
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Thanks for the info. Living in the rockies its a little tough to find 2wd. was hoping a van would make the grade.
60-66 Nut
I'm not sure if a '92 is the same as a late 80's or not. Assuming it is, you can use many components from the Van. The control arms, calipers, rotors and spindles (I know you are going with dropped spindles). The brake booster will be compatable with my booster bracket and the master cylinder should work as well as the prop valve. It is true that the Van steering box will not work, as it turns backwards.
Awesome! Thanks for the help!
