![]() Join Date: Oct 2012
power steering
I know there is a lot of write ups on this subject but everytime I try to do a search it say fatal error for some reason.The question I have what is the best way to shorten and the steering shaft? I have a 83 chevy front end and the power steering box to put under my 65.
Re: power steering
Captan is the MAN when it comes to power steering and disk brakes! PM him and he will hook you up with whatever you need. I have done business with him and I can't say enough about him. Great guy, amazing products, and a wealth of knowledge
Posted via Mobile Device |
Re: power steering
Your wanting to shorten the double d shaft going into the rag joint? I drilled out the factory plastic plug welds and pushed it up to where I needed it, mounted the rag joint to box extended and plug welded back togather
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
60-66 Nut
Re: power steering
The original steering column in the '60-'66 trucks is not a double D design that is colapsable. It is a solid 3/4" shaft.
#5 | |
60-66 Nut
Re: power steering
Thanks for the kind words
![]() Quote:
Re: power steering
#7 | |
60-66 Nut
Re: power steering
You can reuse the original steering column shaft flange, once you shorten the shaft, bu that requires the use of a drill press and it needs to be welded back to the shaft. The installation instructions show how to do this. An alternative method is to use the tube and flange that I sell. This just slides over the original steering column shaft. Once you have it bolted to the rag joint, you simply drill thru the tube with the shaft inside, and install a thru bolt. It can also be welded at any time.
#8 | |
![]() Quote:
We've done these several ways. The easiest by far, imo, is the Captain's alternative where he mentions use of original steer. shaft & his end-tube-with-flange. There are no critical measurements regarding length, as his tube just slides to where it finds and settles on the appropriate length--where, as he states you just drill and bolt. We've even found that with use of a high-grade bolt, welding is optional. ![]() Last edited by luvbowties; 11-27-2012 at 01:54 AM. Reason: spell |
Re: power steering
Thanks for the information. How much is the tube with flange?
#10 | |
![]() Quote:
sam |
60-66 Nut
Re: power steering
There are links to most of my for sale threads in my signature line. Here is the one for the power steering box adapter plate.
http://www.67-72chevytrucks.com/vboa...d.php?t=332923 The tube and flange is shown in the posts indicated in post #1
