Limiting pressure to rear discs
I'm going to be doing a rear disc swap pretty soon and would like to know what is the best way of limiting line pressure to the rear brakes. if anyone has a part number or knows a cheap way to make the whole system function correctly, that would be much appreciated!
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
Re: Limiting pressure to rear discs
A brake proportioning valve is likely all you need
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Aftermarket adjustable prop valves are available through places like Summit, Jegs or other brake specific catalogs.
You can fine tune the brake feel you like with the twist of a knob. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
http://www.summitracing.com/parts/rsd-pv72/overview/
this one? or this one? http://www.summitracing.com/parts/sum-g3905/overview/
Maybe (non adjustable, depends on the pressure slope they've built into the valve)
and Yes (adjustable) K
where is the optimal place to install it? near the master cylinder or just wherever is convenient?
Any where. I would go by the master cyl so it's out of the way
