77 Chevy K10 Silverado Build
Well, first thread, first build, first real true project vehicle for me.. I've always modified, repaired and played with my daily drivers through my younger years, but never had a project vehicle like this that could afford to truly be "built" on the sidelines.
![]() So, long story short, this truck was passed through a few family friends and stuff and ended up parked in my father in laws shop space and sitting for a "someday" project. Couple years later after using it occasionally, he finally said nevermind and I swooped on it. So we know no history on it aside from it having a crate 350 installed sometime before my father in law got it (no idea the mileage) and a B&M transmission went in then too. Every time I open something new or get behind some panel or something, I'm always in for a "Ooh, that's interesting" kind of moment. hah. First day I got it, started it up and drove it around the shop area to see how it felt/ran/stopped/went/turned/etc.. ![]() ![]() ![]() ![]() Not too bad for a truck that’s been sitting for a while! Needs help, but it’s doable. Got new headlights, (found a couple bulbs that weren’t working), fixed a couple lights that were almost just falling out, tightened everything up. ![]() Got a new air cleaner to fix the rusted, beatup, dirty as all get-out, cleaner that was on it. ![]() ![]() ![]() When I was getting the headlights and stuff changed out, the rusty grill and everything was causing me problems, so I updated that a little. ![]() ![]() ![]() Took out the bed bar setup that was just sitting in the back (not actually established there – I guess it was a tester trial piece for a while). Went through the interior to take inventory of what’s good, what needs fixing.. Tightened up all the missing screws, fixed broken tabs, re-routed incorrect switches (the electric window switch unlocked the doors, the door locking switch rolled up and down the windows.. hah). ![]() ![]() Then during one of my running the motor to check operational devices… this ‘rigged’ fuel hose setup split open and started spraying fuel everywhere. ![]() ![]() So now I’m currently fixing the fuel line/fuel pump setup. ![]() Next up, I have the parts in a box and ready for a cooling system refresh. Upper and lower radiator hoses, heater core hoses, new thermostat, new outlet, new coolant, all that jazz. Thanks for looking.. Any encouraging words, tips, advice, do’s/don’t’s, “you‘re never going to make it”'s or general kudos are greatly appreciated. Hah. This will probably be a fairly slow and thorough build as I need this thing to be able to go on longer distance camping trips. So I want to do this all correctly from the get-go. ![]() |
Re: 77 Chevy K10 Silverado Build
As for a new update here, got some time to get out to the truck this weekend. It was raining on Friday though, so I only got about 20 minutes into working on it when all of a sudden it started pouring on me. Rain?!? In Southern CA?!? What is this nonsense?
![]() So I was able to get the new stock hardline fuel line in to place to replace the rubber rigged setup the PO had that bust on me: ![]() Then, at one point from getting in and out of the truck I realized.. so, I'm 6'4 and can easily step up from the ground into the truck.. But most my other friends, my wife, basically anyone else, has trouble being that I have no steps or handles to grab onto.. So I setup a little rig on the metal molding around the headliner. I made sure everything was thoroughly mounted into the metal of the body and should hold relative decent weight as someone is climbing on up into it (or hanging on for dear life along some hectic trails..) ![]() ![]() ![]() So next up now... While putting in the fuel line, the ground to the alternator was completely rusted on and ended up completely busting as I attempted to unbolt it all to get into the fuel line area.. So while I had the alternator completely disassembled, I found that one of the contacts on the inside was frayed and mostly separated. So I need to either replace that, or just get a whole new alternator (which might be the easiest and most cost effective option - it needs to be done anyway). ![]() |
looks like it will be a nice build
PLEASE HELP WITH PROJECT UNDERHAULIN http://67-72chevytrucks.com/vboard/showthread.php?t=306320 Gemini - 1978 GMC C15 High Sierra - 305 c/e - Given to Mother Electra - 1967 Mustang Coupe - 302/w 3 speed Build Chyna - 1968 Chevy C20 Long Stepper
Thank you, thank you. I'm hoping it will be.. Just need to figure out how I can devote more time to it. hah. Its VERY slow going so far.
Cool truck, I like the browns.
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
Thanks!
![]() I have been contemplating repainting something different eventually.. but maybe it's just growing on me now. I'm starting to like it more and more. ![]() |
Second Chance Program
Subscribed.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
Windy Corner of a Dirty Street
Hey buddy! Good to see you here! This is a much better place to add a build thread. Expo is nice too, especially if you are building a Land Rover or Yota Land Cruiser…our old American iron, not so much.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
Cool build I look forward to seeing more, can I ask what you used to shape your fuel line?
1985 Chevrolet K10 Custom Deluxe---SOLD 1997 Ram 2500 5.9 Cummins 1985 Chevrolet Camaro Z28 1987 Chevrolet K10 Silverado "The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257 |
#11 | |
The fuel line was ordered pre-bent, stock replacement, hardline for the 77 Chevy truck from LMC, it showed up maybe 90% "fit" so I had to slightly "persuade" it to fit 100% as it was getting tightened in to place. Worked out great though. And I definitely feel MUCH better about it than the rubber nonsense that was built on the thing beforehand. ![]() |
Kool Truck looks like it already has a lift and tires,tilt and all the goodies,you know the saying THERE'S SUMTHIN BOUT A TRUCK.....
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
just wondering did they put the oil dipstick on the passenger side of a 350
![]() Join Date: Dec 2012
My 1980 K10 has a Chevrolet 350 replacement motor. Dipstick is on the passenger side. Wished I could tell you what year it was replaced.
Posted via Mobile Device |
#15 |
My 78 has the dipstick on the drivers side. I'm not sure what year it changed from the factory to the passenger side, but a lot of our old trucks had engine replacements that had passenger side sticks.
#16 |
ok just wondering the motor that was in my truck had dipstick on passenger side an was told it had a 350 in it but all 305's i seen it was on that side an 350's were on drivers side thanks for info
#17 |
Back in the 70's they had it on the drivers side. Everything that I'm discovering about my truck is that the motor is actually an 87+ motor. It's a crate motor that the previous owner installed. Me thinks it's this one:
http://www.jegs.com/p/Chevrolet-Perf...31165/10002/-1 But I haven't really gotten all the way into the motor yet to pull any identifying markings to verify my theory. But everything so far is pointing towards this.. |
#18 |
Stopped by the truck today to install the new alternator. Still has a broken wire though, so I need to strip and redo the wiring to the new alternator, but it's now bolted up anyway!
100A krinkle black 1-wire: ![]() So after that was accomplished.. I pulled out the little creeper from the shop and I took my first pass through the UNDERside of my truck.. Let's have a look-see.. First I found where the two gas tanks feed into one switch box.. It looked fresh. My father in law must have re-done this in the recent years ![]() Then I noticed all the leakage that he had mentioned to me on the transfer case.. so I decided to get some before snaps of how it sits before I end up pulling the thing to have it rebuilt with new seals. ![]() ![]() ![]() So I was basically "taking inventory" of current situation.. Now I'll know where to move forward. Underside of the bed and the rear suspension: ![]() ![]() ![]() And just to finish off the little update.. I shot a quick pic of the current dual Flowmasters running out the back.. Mm.. Im a fan. ![]() That's all for today folks.. Comments, questions, advice, all is encouraged. ![]() |
#19 |
![]() Join Date: Jul 2014
Any updates? Cool truck!
#20 |
Thanks for the kind words. Looks like my edit of my Flickr account has killed on my pics of it though. And I think the posts are too old for me to edit now. Bummer..
I guess I can just catch up to current pics. I pretty much haven't done anything to the thing. Its just been sitting. I got a 95 Tahoe that I motor swapped and built into a project over a year or two.. then sold it. Now I'm back to pick up where I left off on the 77. ![]() ![]() ![]() ![]() ![]() My goal is to figure out what emissions parts I need to add to this crate motor to be able to transfer it over to CA ownership and make it legal to drive on the roads here where I live. It's currently an Arizona vehicle with no SMOG legality. Any helpful information or links anyone can provide to direct my research would be greatly appreciated. Thanks! |
#21 |
Lets see the RPO sheet!!
#23 |
First would probably be manifolds or headers with smog tubes a smog pump and it shouldn't require a Cat because of the heavy duty suspension Headers must be CARB approved and always seams to change as to which are legal and having the sticker with the CARB certified number helps a lot. intake is probably the original you will need the original style air cleaner with functional heat tube to manifold or header that's all I can think of off the top of my head
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. ![]() 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
#24 | |
