1970 Daily Driver
EZ-EFI™ Self Tuning Fuel Injection System - Any Good?
Just wondering if anyone has used one of these or knows some one that has. Price is too high for me but hopefully they come down a bit some day. I would like to upgrade to an EFI motor but I am too sentimental and want to keep the motor my father and I rebuilt together when I was a kid ( built up 327).
If one of these units realy did work good it would be the best of both worlds. http://www.compperformancegroupstore...stemEZIEFIKits
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
![]() Join Date: Dec 2007
Re: EZ-EFI™ Self Tuning Fuel Injection System - Any Good?
FAST produces great products in general. If you have ample time to learn, Megasquirt is a great option. It's basically a DIY system.
There are threads on this system all over the board. Use the search box for lots of reading. Here is a thread I had book marked.
http://67-72chevytrucks.com/vboard/s...d.php?t=502547
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Its a good system, the only downside I see is the lack of timing control. Although not necessary, being able to control timing is typically a major advantage for EFI systems.
I installed a different self tuning EFI system which can control timing. When using my old vacuum advance distributor, I was getting about 10-11 mpg at 65 mph. When I switched over to a GM small cap computer controlled distributor and tuned it with the computer software, I went up to 16mpg. Clearly, my vacuum advance distributor wasn't set up right, but it was really easy to setup correctly with the computer software. The computer can also handle a knock sensor setup. |
[QUOTE=lts70;5731475] Price is too high for me but hopefully they come down a bit some day.
I wouldn't hold my breath waiting..............
......its not what your askin', its what your gettin'.... .......every time I screw up, I learn something. Needless to say, I'm learning all the time............ |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
I'm just digging up old threads, trying to find information on switching my gen 1 sbc to Computer Controlled Timing.
I recently purchased the FiTech EFI for $995 that features Timing Control. Once I get the TBI all setup, I want to move on to Computer Controlled Timing. I'm searching the Internet to find all I need to make this upgrade.
The fast EZ-EFI 2.0 does control timing if you use their dual sync distributor or a crank trigger.
I'm using the crank trigger on a multiport (ramjet) setup. Install and setup was super easy and fired up beautifully. Unfortunately that is as far as I've gotten until I get the rest of the truck back together. |
#8 | |
x2 http://www.fitechefi.com I have a FiTech sitting on the bench waiting to go into my 69 Camaro. This thing looks very good. ![]()
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
Any reason these kits wouldn't be reliable? If I am tossing a few Gs at one, would be nice to be able to drive 2500 miles without worrying. Yes anything can break, but you know what I mean.
"You can take the man out of PA, but you can't take PA out of the man" |
I've got about 5,000 miles on the FAST EZ EFI 1.0 in my Blazer
5,000 miles include the Rubicon, (2) week long trips to Moab, one Pismo dunes trip, multiple local trips, and hours.... hours.....hours.... of off camber rock crawling. I run a Pro Billet MSD dizzy.
'68 C10 SWB '85 K30 Blazer |
No matter what system you go with, do yourself a big favor and ditch the external, return-less fuel pump for a proper return style in-tank fuel pump. I run the MSD Atomic throttle body unit in my Blazer. It controls the timing and runs like a champ thanks to the timing control AND consistent fuel pressure/delivery.
FWIW, I use an MSD Dual Sync (tm) because it has both cam and crank position sensors, which are required to be able to do sequential fuel injection. It does require an ignition box though (MSD-6AL, the classic, in my case).
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
Check out xludan's build thread. He is running that system.
http://67-72chevytrucks.com/vboard/s...d.php?t=411867
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
Mallory Dual Sync for $114.99
Its an Accel Dist. with the Mallory name on it. http://www.ebay.com/itm/Mallory-7719...xU0iad&vxp=mtr
#15 |
I have a friend that installed the ez-efi 2.0 retrofit kit on a Camaro. he had a ton of problems with it picking up interference with his msd box and pretty much any other wiring that was close to it
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies 2004 2500HD utility bed aka Brutus |
#16 | |
#17 |
the main power wire also cannot or should not be attached in the same spot as an ignition box. with the msd and the ecu main power wires connected to the same post on the junction box the car would barely even run, moving the msd to the battery a couple inches away solved that part
#18 |
Fast does mention several times that the power wires must be connected directly to the battery. Being as my battery is behind the rear wheels I was planning on connecting to a junction point off the starter but I'm rethinking that now.
#19 |
1967 c10 3OTT with R10 overdrive. 385 Stroker, 373 posi FITECH EFI, Vintage air, York 210 OBA, 4/6 drop with riddler 20x8 and 20x10 1957 S5T Leslie Supertyfon train horns and EMD bell "No bolt left unturned" |
