Old 12-01-2012, 12:49 AM   #1
dukcaln
dukcaln's Avatar
slow windshield wipers
so, now that it is raining, the windshield wiper motor seems to be pretty slow. the normal mode seems slow and when switched to the faster mode, there isnt too much of a spped difference. It is faster but not fast enough..... is it the motor or can it be something else... any tips or tricks to make it faster
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP
SOLD 1972 chevy c10
dukcaln is offline   Reply With Quote
Old 12-01-2012, 02:15 AM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: slow windshield wipers
To try something quick & easy, lube the linkage pivot points just under the slots in the cowl. If that doesn't help, it could be the motor.... aside from swapping to a new motor, I'm not sure how you'd prove that.
You might also try cleaning the electrical connections to the motor. If they're not clean, electrical resistance might cause the motor to run slower.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 12-01-2012, 10:16 AM   #3
RexDodge
Found this;
http://67-72chevytrucks.com/vboard/s...d.php?t=532568
You also might consider a relay similar to the head light relay upgrade. Just a thought.
RexDodge is offline   Reply With Quote
Old 12-01-2012, 12:16 PM   #4
pritch
pritch's Avatar
Take a good look at where the shafts come through the cowl. I found that mine had shifted slightly and was causing the shaft to rub on the cowl. I readjusted the cowl and gained some clearance and the wipers went back up to normal speed.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 12-01-2012, 12:33 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
My luck wasn't as good as Pritch's. I ended up changing the motor in the White '67.
LockDoc
Leon
Old 12-01-2012, 12:49 PM   #6
dukcaln
dukcaln's Avatar
thanks, I will take a look at it
SOLD 1972 chevy c10
