Old 12-03-2012, 09:54 AM   #1
mobileortho
mobileortho's Avatar
Shaved door emergency entry
I've been having difficulty routing an emergency (Manual) entry cable to my truck. It keeps binding and does not seem to work very well. I tried a couple of configurations with the intent of keeping it hidden but I keep having the binding issue. I'm sure I can run it on the firewall to the right of the M/C but didn't want to go that route. Anyone have any suggestions?
I was also thinking of hiding another powered switch in the grill area. Will I have to run a relay as well?
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 12-03-2012, 10:12 AM   #2
Billett
Billett's Avatar
Re: Shaved door emergency entry
What remote door kit do you have? The one on my old s10 came with two leads on the end of a long wire, so I could just attach a pair of jumper cables to them and the door would pop. I coiled it up and strapped it inside the frame.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 12-03-2012, 10:46 AM   #3
youngrodder
youngrodder's Avatar
Not sure what door latches that you are using but I just attached a small SS cable and it hangs straight down from the latch. I put a loop in the end of the cabel and it just barely sticks out at the bottom of the door from the weep hole.
I also wired mine so that with my remote I can not only pop the door but also roll down either window. My door popper kit is from Dakota digital.
Good luck
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 12-03-2012, 10:48 AM   #4
andrewmp6
Billett like this http://www.avsontheweb.com/product.p...cat=138&page=1
Old 12-03-2012, 11:13 AM   #5
Billett
Billett's Avatar
Exactly like that. I bought AVS's kit directly from them, for the 2nd gen s10s.
Will
2024 Toyota Sienna
Old 12-03-2012, 12:23 PM   #6
mr48chev
mr48chev's Avatar
I've seen several done like Youngrodder said he did his. It's simple and it works. A guy could use regular welding rod or pick up a length of stainless rod from most welding supply stores to make it out of.
I've caught flack from non car guys looking at my truck because it doesn't have door handles giving me hell because they say an emergency worker wouldn't be able to get in the truck if I were in a wreck. With the suicide doors they will most likely destroy the truck if it came to that anyhow.
Some have even claimed that it was illegal as the doors couldn't be opened by someone else from the outside.
My ongoing truck projects:
Old 12-03-2012, 02:03 PM   #7
OrrieG
OrrieG's Avatar
[QUOTE=mr48chev;5737288
I've caught flack from non car guys looking at my truck because it doesn't have door handles giving me hell because they say an emergency worker wouldn't be able to get in the truck if I were in a wreck. [/QUOTE]
Apparantly their fire trucks do not carry fire axes, hot saws or the jaw of life. I once got trapped in the crawl space (minor cave in). Wife wanted to call the FD, I said no they would have just cut a hole in my hardwood floor. She came down and dug me out.
Old 12-03-2012, 07:24 PM   #8
_Ogre
_Ogre's Avatar
Originally Posted by OrrieG View Post
... I once got trapped in the crawl space (minor cave in). ...
did she take a video? i'm sure there's more to that story
shop air compressor timer
Old 12-03-2012, 02:02 PM   #9
_Ogre
_Ogre's Avatar
bicycle brake cable.
i have 5 shaved latches on my 58 truck; both doors, gas door, trunk and tonneau cover.
each one has 3 means of access to unlock them with the exception of the gas door that only has 2.
for the doors i ran bicycle brake cable in the sheathing with a brake adjuster fitting on both ends to lock it in place.
by locking both ends in place the cable and sheath can run a serpentine route to any where your heart desires.
under the hood i just drilled a 5/16 hole in the the firewall and attached the brake fitting through the firewall.
here is my door solenoid with the under hood safety cable attached on the solenoid bracket
i'm running stock door latches and just have looped ends that slide over the latch mechanism
my biggest problem was how to run the bicycle cable, speaker wires, power window wires and solenoid wire thru the door loom without binding.
not sure how the ad trucks work for pre-made door looms, but they didn't work for the task force doors.
i made my own from 3/4 square tubing, some plate and a roll pin pivot
the door looms have worked well for 3 yrs. they slide into a plastic bushing in the door
for my redundant safety cable i have a loop of bicycle brake cable in the door handle grip
hope this helps, it may not be your plan but it may give you an idea of how to solve your dilemma.
i can say this: if you don't do a backup system you will be breaking in to your truck at one point or another.
in case of an accident and i am unable/unconscious to open the doors
i'm sure the emergency workers know how to break a window out
Old 12-03-2012, 04:13 PM   #10
Billett
Billett's Avatar
I got a lot of the same flak. If I can't open my door or crawl out a window, chances are the wreck was bad enough that the jaws of life are needed anyway. If I die because it took them an extra 5 mins to cut me out, well, that's the risk we take LIVING. Plenty of people are killed in cars with regular doors. Stuff happens.
Will
2024 Toyota Sienna
Old 12-03-2012, 04:33 PM   #11
NEWFISHER
NEWFISHER's Avatar
Billett- that is way too much common sense in one post on the internet, good job!
NEWFISHER is offline   Reply With Quote
Old 12-04-2012, 12:26 AM   #12
mr48chev
mr48chev's Avatar
That's what I figure. I could never fit my fat bod though the window on a good day but emergency workers have a way of figuring out how to get in cars or trucks and don't much care what gets torn up.
The comments were never made by emergency workers but by non car people at shows or at the 7-11 or the parts house I used to work at where we had some "real" self styled automotive experts show up on an all too regular basis.
Old 12-03-2012, 06:15 PM   #13
Highsider
Highsider's Avatar
Orrie- you have too much excitement in your life!
"I once got trapped in the crawl space (minor cave in). Wife wanted to call the FD, I said no they would have just cut a hole in my hardwood floor. She came down and dug me out."
Highsider is offline   Reply With Quote
Old 12-03-2012, 08:42 PM   #14
mobileortho
Never thought about the drain hole! Gotta try that one!!
As far as shaved doors and accidents go, I agree with Orrie & Billett! Nuf said.
Robert C.
1950 3600
Old 12-04-2012, 01:07 AM   #15
andrewmp6
A spring loaded center punch in the glove box is all you need.Its a cheap little tool about the size of a thick ink pen and it will bust out any auto glass side window easy.
