69' Chevy Stepside
![]() Join Date: Mar 2008
Pacesetter TBSS Long Tube Header Install on my 6.0L in my 69' C10
Over the last couple weeks I picked up a set of Pacestter long tube headers (1 3/4", 3" collector) made specifically for a Trailblazer SS. After reading about c10seconds success with the Kooks TBSS headers. Anyways these Pacesetter version fit with a couple mods to the frame on the drivers side, I had to cut out the lower frame slightly so the collector would fit since it is swept over for the trailblazers front driveshaft.
I bought them from Amazon, free 2nd day air shipping to Alaska so I couldn't beat the deal on them Part number was 72C2276 for the ceramic coated headers and I bought the cross over pipe for the trailblazer as I hopped it might fit too but it did not still used it with some major modifications. ![]() Anyways overall the fit is good enough for me! Here are some pics of what they look like installed on my truck and also a detailed video of the top and underside. ![]() ![]() ![]() ![]() Watch video here:
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver |
Location: Sunny, Florida, some might call it South Alabama
Re: Pacesetter TBSS Long Tube Header Install on my 6.0L in my 69' C10
I am doing the exact same setup except using an LQ4. Do you know what kind of power you are putting down?
Just sold my C10...sad day... Looking for a 1972 Blazer to hopefully fill the hole in my heart. |
#3 | |
69' Chevy Stepside
If I get a chance this summer I might get it on a dyno and see what number it will put down. I also plan to take it to the track this spring and get some drag radials and see what it will run with these headers. Best I did before on a base tune was 13.4 spinning out and the tune not living up to its full potential. Now the tune is better and traction is more of an issue and I'm sure the headers will add to that problem lol...
I just used a set on a 67 and had to do very little triming.
I have these same headers arriving tomorrow. I was really hoping i could avoid any frame mods. Any info on your engine placement? I see stock engine towers. Are they in the front v8 holes? Also what engine adapter plates are you running? Do you think i could modify the header collector and get by with no frame notch? I'm running Pol stands and the plates that move the engine forward about an inch.
Posted via Mobile Device |
#6 | |
69' Chevy Stepside
#7 | |
subd
70 C10 working on a LSx swap ![]() 4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol |
I'm trying to buy the rest of my exhaust and my engine is at the machine shop so I can't mock the headers up just yet. Any chance you could give me the center line dimension between the collectors? I'm basically buying a universal x pipe kit and the width determines the length too and I wanna make sure I don't need more pipe. Thanks in advance man.
#10 | |
69' Chevy Stepside
How far below the frame do the headers extend?
#12 | |
69' Chevy Stepside
Thanks, I also enjoyed you video on the build of your engine. I think Im staying stock, just adding headers for now. Would I have to get my ecm reprogrammed if I added a cam? Oh, I also watched the vid of the guys doing the harness. I didnt know that was yours.
#14 | |
69' Chevy Stepside
#15 |
What kind of plug wires are you using that clear those headers?
#16 |
69' Chevy Stepside
The plug wires aren't great and are a little on the short side in some places, but they are the plug wires for a 96-98 K1500 Truck. With some persuasion they clip onto the coil packs that I have relocated in the frame rails and with some "custom" zip ties to keep them from touching anything they seem to work great. I would look into a MSD wire kit, that's what I was going to use but didn't want to pay the price.
#17 |
Kind of digging up an old thread, but do you remember how much you had to trim off of the driver side frame rail to clear the collector?
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
#18 |
Collector fits like a glove. No trimming needed. #1 primary requires clearancing on top of frame rail. #2 primary is very tight against plug wire. Nothing to do with frame. Just poor design. Plan on bendable MSD wires and heat socks. Not a problem though.
#19 |
Thanks for that info. I thought the #1 primary looked a little tight in the picture, but I guess those clearances might vary a little depending on motor mount setups.
#20 |
https://www.dropbox.com/s/stwu9sa7yn...195412_521.jpg
https://www.dropbox.com/s/oxyhuhdwiw...195537_790.jpg https://www.dropbox.com/s/kpoerijavj...195527_058.jpg https://www.dropbox.com/s/4wjzau2ckx...195505_881.jpg https://www.dropbox.com/s/74v1iqkroc...195452_539.jpg https://www.dropbox.com/s/xhql1osfyi...195444_855.jpg https://www.dropbox.com/s/j5bxh7guxn...195422_454.jpg https://www.dropbox.com/s/jwz44uikqg...195354_480.jpg https://www.dropbox.com/s/1wkt1wz8ud...195400_235.jpg https://www.dropbox.com/sh/rr4zm094h8fvtal/mfo8dGHJhx |
#21 |
#22 |
Pain in the rear to click all the links, but I didn't feel like downsizing all those pics. If you're considering the headers it is definitely worth the clicks.
#23 |
I appreciate you sharing the pics. They look like they fit really nice, and the price helps too.
#24 |
And no aftermarket oil dipstick required?
#25 |
