12-04-2012, 02:35 PM | #1 |
Drum to disk conversion
Hey everyone,
I'm looking to convert the front drum brakes to disk brakes. I looked around for a couple of kits but most of them are 5 lug. I want to keep my truck a 6 lug. So if anyone has done this can you please help me out by sharing pictures or knowledge... Also most kits are saying if your truck is a 70 or older you need to modify the firewall, again pictures or knowledge on this is greatly appreciated. Thanks guys!!!! Posted via Mobile Device |
12-04-2012, 02:40 PM | #2 |
Re: Drum to disk conversion
I haven't seen the parts YET but ordered a kit for the front of my 70 3/4 ton in 8 lug from Tucker's Classic Parts. They assured me they are American made. The price was OK but not killer. Look at the 6 lug kit and see if it's what you need.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 Last edited by Longhorn 70; 12-04-2012 at 02:46 PM. |
12-04-2012, 02:49 PM | #3 |
67-72 parts collector,…
Why would you have to modify the firewall?
12-04-2012, 02:56 PM | #4 |
I looked at summit at a conversion kit, unfortunately it was a 5 lug, but they left a note saying: Summit® disc brake kits are manufactured to meet or exceed DOT standards. Kit includes 2 in. lowering spindles. Kit includes braided brake lines. 5 x 5 in. bolt pattern. Will only work on trucks equipped with a bail-type master cylinder cap retainer. Will not work on trucks equipped with a bolt-on master cylinder cap retainer.
Then I checked CPP for a kit and found a 6 lug kit, once again there was a note saying: Kits will fit 1967-70 trucks when modifying the firewall. Here's the link to CPP's 6 lug kit http://www.classicperform.com/Store/...0CBK-55213.htm Posted via Mobile Device |
12-04-2012, 03:06 PM | #5 |
www.EarlyClassic.com would be my first choice.
Call ECE and let them fix you up. This would be my second choice: Look at this kit. http://www.performanceonline.com/196...d-6-LUG-16671/
12-04-2012, 03:08 PM | #6 |
12-04-2012, 03:14 PM | #7 |
Took a look at both links, I like the second link
Tags |
conversion kit, disk brakes, drum brakes, suspension |
