12-04-2012, 06:32 PM | #1 |
Tailgate Rod clips
I am having a hard time finding tailgate rod clips. The clips or locking nuts that go on the end of the rods and into the tailgate latch so they do not fall out of the latch itself. I cant find them in any magazine I have. Does anyone have a part number or something close that would work at the parts store even. They dont have to be original just fit. Thank you
12-04-2012, 06:37 PM | #2 |
Re: Tailgate Rod clips
12-04-2012, 06:43 PM | #3 |
Thanks for the reply but no, they go onto the inner rod and connect to the latch itself. (#5 in that diagram) I hope Im not dreaming these because wouldnt the rods fall out over time on the latch? I know i remember taking something off them to get the latch out.
12-04-2012, 09:03 PM | #4 |
i always found these clips very hard to find, i have threaded the end of the rod and put nuts on them to hold them on, and also drilled a hole in the rod and put a cotter pin with a washer to hold them on, worked good for me....maybe this will help...
12-04-2012, 09:32 PM | #5 |
I call them barrell clips or bolts. a good hardware store should have them if not I have them available. can purchase them online at http://s-c-t-p.com/clipsfasteners.html , or you can email me at atheystruck@comcast.net
atheystruck@comcast.net 67 1/2 ton 4wd custom cab 72 1/2 ton 4wd super cheyenne 71 1/2 BB super cheyenne shortbed |
12-04-2012, 09:45 PM | #6 |
What?
Clips like that are best salvaged from original stuff.
The new clips I found are not strong enough, so they would just pop off after a few times using them.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
12-04-2012, 10:55 PM | #7 |
My NAPA Store has them.
12-05-2012, 08:12 AM | #8 |
1969 Custom 30 wrecker
I recently went through this and just used some of the clips that hold inner door latch rods in place. (also used on other areas like throttle rods, choke rods, etc)
Was a bit challenging getting them in but now those rods stay put!
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
12-05-2012, 01:28 PM | #9 |
Registered 1971 K5
Would'nt that be #10 in the picture?
12-06-2012, 10:28 AM | #10 |
12-06-2012, 12:44 PM | #11 |
Yes I beleive you guys are right. Guess I just didnt look at the picture clearly enough. I couldnt tell what that was off to the side but now it makes since. thanks
