12-05-2012, 10:43 AM | #1 |
454 MAKES IT ROAR
Exahast routing?
Can anyone in the know please tell me if it's possible to run the exhaust over the original trans crossmember? or will I have to swap it out for something like this from ECE?
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
12-05-2012, 12:03 PM | #2 |
the boat guy
Re: Exahast routing?
I have my duals ran over my original crossmember and through the crossmember behind that. Way cleaner than hanging under the frame.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
12-05-2012, 12:08 PM | #3 |
I did mine withe ece but will work with original here's mine with ls conversion.
Posted via Mobile Device |
12-05-2012, 12:25 PM | #4 |
454 MAKES IT ROAR
That's good news brad_man I think to save money I'm going to keep the original member now that I know it's possible, but that ECE cross member sure looks clean, definitely the way to go in the long term.
Thanks sincerely guys..
12-05-2012, 12:50 PM | #5 |
Project Junkie! Fishing Poor!!
Just came in to say Good Morning, Nigel!! and are you going to run a 3" exhaust? WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
12-05-2012, 01:04 PM | #6 |
454 MAKES IT ROAR
Good morning mate...another day another $.
Well the existing is 2 1/2", it's an area I will admit I know little about, should I consider going 3"? what are the benefits? And don't forget my shipping quotes....
12-05-2012, 01:12 PM | #7 |
The benifates are 3" exhaust will breath better and the sound is killer.. As for the quote, you didn't get it? Resend your list, because my computer died a while back and I lost a bunch of stuff. WES
12-05-2012, 01:01 PM | #8 |
Just to give you a look at a different setup
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
12-05-2012, 01:13 PM | #9 |
454 MAKES IT ROAR
Thanks for that Will.
12-05-2012, 01:41 PM | #10 |
No problem at all. I would go for a 3" if I were to do it again, but mine is 2.5" because my 350 is completely stock. Still sounds amazing though. What kind of mufflers are you going with?
12-05-2012, 01:54 PM | #11 |
454 MAKES IT ROAR
Planning on keeping the old Flowmaster 40's that the PO had installed, they're still in pretty good shape, and I've always been happy with the sound, although I did sneak a peek at the 10 series....but I think I should really consider my neighbors.
12-05-2012, 05:28 PM | #12 | |
The concept that maximum power is obtained by zero pressure in the exhaust is only partially true. There should be absolutely no back-pressure from the collector rearward, but the diameter of the system beginning with the exhaust valve is a compromise. The highest efficiency for the system requires a minimum speed for good exhaust gas velocity to insure that gas does not "back up" into the chamber during overlap at low engine speeds, and that the "suction" (negative pressure pulse) effect of a resonant (tuned length) and/or collector (overlapping exhaust pulses) system is optimized. To predict what primary size will be best for a specific motor, you must know where you want the engine to develop peak torque. If the existing torque peak is at bit lower RPM than you prefer (typical in under-cammed or stock motors), it can be "bumped" a bit by increasing the primary diameter. If the torque peak is too high (motor is "peaky", with no range and poor recovery from gear changes), the peak can be adjusted down by using a smaller pipe. A change of 1/8" in the primary diameter will raise or lower the peak torque RPM by 500 or so. This factor slightly overlaps the effect of primary pipe length, but the pipe length generally will not change the peak torque or the RPM at which it occurs. A length change has the effect of improving the torque on only 1 side of the peak by "borrowing" it from the other side. A shorter pipe improves the torque after the peak (reduces it at lower RPM), preventing the curve from flattening out so quickly as speed increases. A longer pipe extends the torque curve backwards to improve the engine's flexibility, at the expense of after-peak torque. Less stall speed is required, and the motor will pull taller gears; this re-tunes a 4-speed motor for better operation with Torqueflite, etc. For best effect, the gas speed in the primary tube at the peak torque RPM should be about 240 feet per second. The formula to calculate pipe size is: Area of Primary Pipe = RPM × Cylinder Size ÷ 88,200 This determines the pipe's cross-sectional area, from which we can calculate the ID. Typical exhaust pipes are 18ga. (wall thickness of .049"), so the OD will be .098" larger. From this we can construct a formula for an 8 cylinder motor, and factor in the 18ga. wall thickness: Area of Primary Pipe = RPM × Motor Size ÷ 705,600 Pipe ID2 = RPM × Motor Size ÷ 705,600 ÷ .7854 Pipe ID2 = RPM × Motor Size ÷ 554,177 ID = (RPM × Motor Size ÷ 554,177).5 OD = (RPM × Motor Size ÷ 554,177).5 + .098" The following Chart shows exhaust pipe outside diameter, based on this formula, for various motor sizes and speeds. To determine if your pipe size is large enough, search across the top row for your motor size (interpolate if in between 2 sizes), and then down that column for your current pipe OD. If the peak torque RPM in the left column is high enough, your pipe is not a restriction. If the peak torque RPM is lower than where you feel your torque peak is, look for the pipe OD on the line with your torque RPM. If your primary pipe's wall thickness is 16ga. (.059"), add .020" to the OD figure to compensate. Here is a table of exhaust Pipe Size @ Peak Torque RPM vs. Motor Size Engine Displacement (all MOPAR some stroked some not) 273 318 340 360 392 410 383 400 426 440 451 494 RPM Tube size for optimum flow 3000 1.31 1.41 1.45 1.49 1.55 1.59 1.54 1.57 1.62 1.64 1.66 1.73 3250 1.36 1.46 1.51 1.55 1.61 1.65 1.60 1.63 1.68 1.70 1.72 1.80 3500 1.41 1.52 1.56 1.61 1.67 1.71 1.65 1.69 1.74 1.77 1.79 1.86 3750 1.46 1.56 1.61 1.66 1.73 1.76 1.71 1.74 1.80 1.82 1.84 1.93 4000 1.50 1.61 1.66 1.71 1.78 1.82 1.76 1.80 1.85 1.88 1.90 1.99 4250 1.54 1.66 1.71 1.76 1.83 1.87 1.81 1.85 1.91 1.93 1.96 2.04 4500 1.59 1.70 1.76 1.81 1.88 1.92 1.86 1.90 1.96 1.99 2.01 2.10 4750 1.63 1.75 1.81 1.85 1.93 1.97 1.91 1.95 2.01 2.04 2.06 2.16 5000 1.67 1.79 1.85 1.90 1.98 2.02 1.96 2.00 2.06 2.09 2.12 2.21 5250 1.71 1.83 1.89 1.94 2.03 2.07 2.00 2.04 2.11 2.14 2.17 2.26 5500 1.74 1.87 1.93 1.99 2.07 2.12 2.05 2.09 2.15 2.19 2.21 2.31 5750 1.78 1.91 1.98 2.03 2.11 2.16 2.09 2.14 2.20 2.23 2.26 2.36 6000 1.82 1.95 2.02 2.07 2.16 2.20 2.13 2.18 2.25 2.28 2.31 2.41 Note: 392" is 340/360 block stroked with 3.79" crank; 410" is 340/360 block stroked with 4.00" crank 451" is 400 block stroked with 440 crank; 494" is 400/440 block stroked with 4.15" crank Remember that your peak torque RPM will always be lower than your peak HP RPM. The separation between peak torque and peak power is roughly proportionate to your range of useable power (wider is better). Be realistic in your estimates and plans - peak torque @ 7000 RPM sounds good, but is almost certainly beyond the breathing ability of even a professionally-built race motor, and if true will make the car impossible to launch. Note that 1-1/2" pipe is large enough for a 273" motor with max torque @ 4000 RPM. A 360" only needs 1-3/4" for 4200 RPM. A 440" is fine @ 4500 RPM with 2" primaries. If choosing pipes for a 4WD, van, towing, etc. keep the size small to improve torque where you need it most - the lower RPM ranges, typically 2500-3500. One exception where use of a larger pipe (than indicated by the above formula) will help power is, of course, motors using nitrous oxide, supercharger or turbocharger. In these cases, size the pipe for the expected peak torque, not the motor size. Another instance where a slightly larger pipe may help is where the departure angle of the pipe from the flange is very sharp (typically downward). The added cross-sectional area immediately after the flange apparently helps reduce the restrictive effect of a small radius after the port. This partially explains why some header models or brands work better than others with similar dimensions. So, the bottom line is bigger is not necessarily better AND the average Joe Bag-O-Donuts can't tell the difference in pipe size without getting out on the track for a couple of years! |
12-06-2012, 01:54 PM | #13 | |
Excellent reply, backed up with an indisputable technical explanation!
12-06-2012, 05:08 PM | #14 |
454 MAKES IT ROAR
Not a problem Will, it's all good info.
Well I got a price from the exhaust shop...they only work on Mustangs but he reckons he can do mine. I also found while searching bruin_d's routing of his exhaust on his Burb, I took the liberty of copying his pics and forwarded them to my guy and the second price is for that layout......now I need to make some stateside calls for short tube headers. He said... To cut out the center cross member fabricate tubing to accept the new exhaust piping use your existing mufflers and exit in front of rear wheels mild steel $882 stainless $1,203 Or... to route as in pictures (no cutting of cross members ) using your mufflers mild steel $601 stainless $922
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger Last edited by eightbanger; 12-06-2012 at 05:13 PM. |
12-05-2012, 02:00 PM | #15 |
Haha I hear that. I went with the super 44's and I love the sound.
12-05-2012, 02:35 PM | #16 |
454 MAKES IT ROAR
Such a good sound, I know some folks hate them but im a fan.
Cool lookin shop truck Will.
12-05-2012, 03:07 PM | #17 |
Thanks! Be sure to post up a video of yours once it's done!
12-05-2012, 04:48 PM | #18 |
Yes, it is! Over the trans crossmember, through the trailing arm cross member, through the cross member over the rear axle then down under the bumper.
12-05-2012, 05:16 PM | #19 | |
454 MAKES IT ROAR
Found your pics today Fitz when I did a search before posting this question, your running Sanderson headers, I was going to go with Hooker shorty's....for no other reason than it already has long tube Hookers on there now.
12-05-2012, 05:45 PM | #20 |
Nigel, either header is a good choice. The shortys will give up some low end torque but, unless you are drag racing you probably will not be able to tell the difference between them and a set of long tubes. I happen to like sandersons but it's a personal thing that has nothing to do with performance.
12-05-2012, 06:11 PM | #21 | |
454 MAKES IT ROAR
Look after that very bad and beautiful 572.
12-05-2012, 04:57 PM | #22 |
Do your trailing arms hit those shiny mufflers, or do your bump stops hit first? Looks to close for comfort to me... Great setup though!!
12-05-2012, 05:43 PM | #23 |
5,000 miles after it was built the trailing arms have never hit the mufflers. Those pics were taken lying on the floor under the lift so they look closer together than they actually are.
12-05-2012, 07:57 PM | #24 |
summit short truck headers $150 (have a pace setter tag, came in pace setter box), thickest flanges and pipe I could find, slight frame clearancing. They go over the stock trans cross member (plenty of room), through the trailing arm cross member and out under the frame in front of the rear tires.
headers- http://www.summitracing.com/parts/su...make/chevrolet
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676 03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582 |
12-05-2012, 08:14 PM | #25 |
454 MAKES IT ROAR
Cheers mate, don't know where i'd be without this forum....Yeah I do, in the soft brown smelly stuff. lol
