Help! Intake and exhuast gaskets on inline 250????
Hey everyone, I have a question in regards to the intake and exhaust manifold gaskets, trying to figure out the mating or installation of the gaskets. I Know on the gasket that mounts to the header the flat side goes towards the header with the metal facing the intake and exhaust ports am I correct on this???? the one that is baffleing me is the one for in between the the intake and exhuast below the carb, I have two gaskets one that is solid and one that is just the outline of the manifold, so which one goes in there and which way does the metal side face, intake or exhaust side???? Keep in mind this is for a stock inline 250, I have searched but cant find any info on this so I appreciate everyones help on this. Thanks...............
Dennis N. USN Ret. Patriotism is your conviction that this country is superior to all other countries because you were born in it. ![]() |
Re: Help! Intake and exhuast gaskets on inline 250????
Use the one w/the cutout and I put the metal side towards the exhaust manifold.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
ditto
1965 long bed ( grandpas old truck ) 1964 long bed BBW Custom Cab 1966 Short stepside 1964 long bed 1965 long bed Custom Cab, factory air, V-8, powerglide |
Thanks, I do appreciate it, thought I had maybe doing something wrong but had it right all along, guess I am gong to have to put some copper gasket goop on it, to isolate the leaks. Thanks again
Yeah, it'll help. Also...if you leave the intake/exhaust bolts a little loose when you mount the two back together, it'll make alignment a little easier. Once you have the manifolds bolted to the head, then tighten up the 3 that hold the two manifolds together.
![]() Join Date: Sep 2009
also put the gaskets on torque them down start engine warm it up then let cool and retorque
#7 | |
Check the flanges to see if they're flat. They may be warped which would make them not seal evenly.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
