12-07-2012, 11:33 AM | #1 |
1968 step side front end conversion
I have found a 1983 chevy pick-up I can get the tilt wheel and the entire front end and other pieces from. Will the tilt wheel and the front suspension work with my 1968 stepside?
Thanks-Mika |
12-07-2012, 12:53 PM | #2 |
Re: 1968 step side front end conversion
everything should work the column might need a little fab tho. the front suspension should bolt up also minus two holes if i remember correctly
77 CHEVY - SHORT BED STEP SIDE 2WD 02 CHEVY - EXT CAB SHORT BED Z71 7 INCHES OF LIFT |
12-07-2012, 01:11 PM | #3 |
Another Option is to find a 1971-72 Longbed with tilt and swap out everything then its a direct fit.
