Old 06-05-2003, 04:24 PM   #1
dubie
dubie's Avatar
Engine mount rubbers
Are the rubber mounts the same between the inline 6 and the 350 small block? I need to know what to order for my engine swap so I can get my engine mounted back in the truck
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 06-05-2003, 04:41 PM   #2
1971Stepside
Almost Satisfied
1971Stepside's Avatar
I believe they are the same...
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 06-05-2003, 11:29 PM   #3
crazy longhorn
Fabricate till you "puke"
Yes, V8 sb & I 6 mounts are the same crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
