![]() Join Date: Sep 2011
I have been trying to clean up a few 72 panels and I'm looking for tips on what to do with gouges in the plastic. What might you have tried that works?
1967 C10 SWB Owner - Rustbelt Restorations |
Re: 72 Door Panel Repair
I would be interested too. Mine look pretty bad and can't seem to locate decent ones.
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
I'm interested too as I will be restoring mine soon.
![]() Join Date: Dec 1999
I always put them in my blast cabinet turned the pressure down and blasted them completly than washed them down good wiped them off with thinner and dyed them with SEM's dye.
Florida Edition
![]() ![]() Join Date: Oct 2010
I actually sanded mine down until the surface was consistant, turned out pretty good. Used SEM adhesion promotor, color and low luster clear.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Reno, Wow those look good, I really like the two tone touch you did. Not factory but should have been awsome
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Florida Edition
Thanks Mr Blue. My trucks pretty much made up of parts from 67-72 so everything is factory but nothing is correct
![]() and so far no one has noticed that I sanded the panels down...... ![]()
I bought good used ones from the parts board here .
Mine are in good shape just faded, They look sky blue now. I may take your idea when i redie them. I really like the two tone look
![]() Join Date: Oct 2012
For me, a lot of hard scrubbing got them from this......
![]() ![]() To this...... ![]() ![]() |
Florida Edition
You did a real good job on those Tex.
![]() Join Date: Oct 2011
are you making any progress on your panels Dave?
Dave "... government even in its best state is but a necessary evil. Thomas Paine "It wasn't a lie, it was ineptitude with insufficient cover." Donald Draper (Mad Men) |
Well I see there has been a little conversation going on over here, guess I wasn't subscribed to my own thread?????
But I have been busy trying out a "few" techniques.........Here is a little tease of what I got accomplished...
Those look really nice, great job
#15 |
Hey Hos, the turnaround is stunning! Are those the same panels??
![]() Im only half joking though...was that scroll work above the the door and window handles revealed by removing the woodgrain trim piece? Also, in these pics I can't even tell where/how you were able to doctor up all those nics/scratches. Nice job though, however you did it. Those panels look sweet.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor. ![]() |
#16 |
Those look fantastic! You gotta share your secret.....
#17 |
Yes, please share your secret.
#18 |
hey dave, did you manage to duplicate the texture in those tiny little nicks?
#19 |
Thinking out loud here, but wouldn't this be a good application for a soda blaster?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
#20 |
![]() Join Date: Oct 2006
#21 |
Those look great! I look forward to the write-up on the techniques you have used to get those panels looking so good.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
#22 |
DaHos, The suspense is killing us. Please share what how you did it.
#23 |
Step 1. Clean with Orange pumice hand cleaner using gray or red Scotchbrite pad.
Step 2. Wipe down with Acetone. Step 3. Apply a few light coats of Bulldog Adheision Promoter. Step 4. Use SEM Bumper Repair #68422 to fill the gouges. DO NOT overfill the gouge. Step 5. Use SEM Texture Coat #39853 - adjusting pressure for desired texture. Step 6. Use Scotchbright pad to scuff high spots from surface. Step 7. Apply light coat Bulldog Adheision Promoter. Step 8. Apply light coats of SEM Color Coat top coat. Parchment is SEM #15103 Super White. Step 9. Clear coat with SEM Color Coat - Satin Clear #13013 Step 10. Enjoy !
1967 C10 SWB Owner - Rustbelt Restorations Last edited by DaHos; 12-18-2012 at 10:21 PM. |
