Old 12-09-2012, 03:39 PM   #1
tismy55
Installing k5 4x4 axle housings onto 66 swb
Is there any information on installing k5 4x4 axles & housings onto a 66 swb frame. Thanks for any help
tismy55 is offline   Reply With Quote
Old 12-09-2012, 03:48 PM   #2
padresag
Re: Installing k5 4x4 axle housings onto 66 swb
check this thread out
http://67-72chevytrucks.com/vboard/s...d.php?t=448681
ron
padresag is offline   Reply With Quote
Old 12-09-2012, 04:06 PM   #3
tismy55
I look at that but I don't see information on installing K5 blazer axle housings onto the frame of a 66. Am I missing something
Old 12-09-2012, 04:24 PM   #4
padresag
do you know what the difference is between the k5 and a regular 4 x 4 p/u is?
What is so special about the K5?
ron
Old 12-09-2012, 05:29 PM   #5
tismy55
nothing special I just happen to have a K5 and a 66 I just wanted to make my 66 a 4X4 Thats all
Old 12-09-2012, 05:42 PM   #6
padresag
so if it is nothing special in the difference what is the problem with the thread that I supplied. I read your original question and I replied with that thread for the answer. in that thread is also a K5 axle installation in a 65 frame. Jon's installation is the same basically, just a bigger rear axle housing-dia-3/4t.
ron
Old 12-09-2012, 05:51 PM   #7
padresag
you didn't say what year you k5 was. there are some differences'
I presume that you are also going to use the blazer suspension. there is a difference in spring size depending on which year it comes from. In Jon's applcation and the other they are from 73-87 variety except for Jon's. they used that suspension until 91 in suburbans.
ron
Old 12-09-2012, 06:07 PM   #8
tismy55
I may have overlook the part where it talked about swapping axles in the thread My K5 is a 76. I will go back and look at the thread again. Thanks
Old 12-09-2012, 08:25 PM   #9
padresag
this is a "K"5 application that was installed on this 65 gmc frame
helps when you put in the link
http://67-72chevytrucks.com/vboard/s...d.php?t=555508
ron
Old 12-09-2012, 08:30 PM   #10
padresag
here is some more pics of the spring hanger install. this is the later p/u or k5 spring setup
ron
