Old 12-10-2012, 07:42 PM   #1
JCampbell
Overdrive Swap Economics
Starting to get serious about putting my dually back together. I've been focusing a lot on my options regarding the transmission. I've been seriously contemplating replacing the TH400 with a 4L80e to gain a little highway MPG, but now I'm wondering if the headache and expense will be worth the hassle.
It's not a daily driver. I'd be surprised if it'll see 7,000 miles/year, and 90% of that will be city driving. The only steady highway mileage it will see is the occasional 2,000 mile trip from SoCal to Washington and back. I don't do much heavy towing...maybe 10,000# (max) 2-4 times a year. It's really more of a heavy cruiser than anything else.
The truck was getting 11MPG before the rebuild with a Quadrajet. The new engine will be a TBI unit, so I assume the mileage will stay about the same. Anyone done this conversion before? What are your thoughts?
There's a link to the build thread in my sig.
JCampbell is offline   Reply With Quote
Old 12-10-2012, 08:24 PM   #2
SCOTI
SCOTI's Avatar
Re: Overdrive Swap Economics
I went through this exact scenario when swapping the bbc in my dually (is it worth the investment given the limited use/range to swap the th400 for a 4l80e OD trans while things are apart?). Even w/the 4l80e already in my possession, it was looking to be about a grand to do the swap in a user friendly configuration. Factor in freshening-up the trans & it was quickly getting expensive.
From my point-of-view, you're 100% dead-on:
  • OD has minimal to zero impact for city driving.
  • At a 1-2mpg gain, how many miles would be required before recouping the initial expense for the swap? Something that sees limited seat time takes that much longer to recoup the investment. Until that point in time, it's just an added expense.
Obviously, the one absolute 'pro' for a mild TBI motor would be the rpm reduction while on the open road. Quieter is better when driving mile after mile IMO.....
I decided to stick w/the th400. I am still considering future options though & one is a company that builds 700r4's to live in HD truck apps (I found the info on this site in another thread). To me, a 700r4 built to survive a bbc/torque environment would be the best option as it gives the benefit of the deeper 1st gear for getting these fat f@#kers moving (3.06 vs 2.48); the ease of swapping (multiple swap kits w/o the need for electronic management), & a better OD ratio (.70 vs .75).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-10-2012, 08:40 PM   #3
JCampbell
Got any info on that 700R?
Old 12-10-2012, 08:53 PM   #4
SCOTI
SCOTI's Avatar
http://performabuilt.com/heavy%20hauler%20700-60E.html
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-11-2012, 12:17 AM   #5
jimbonice
jimbonice's Avatar
Throw some 3.54's in the back and you'd be good. I've got a 700r4, and I may still put some taller gears in it. Never been a fan of 4.10's or lower.
jimbonice is offline   Reply With Quote
Old 12-11-2012, 02:58 PM   #6
Chevyman350
There are alot of factors that go into the fuel economy.
The most significant of which is putting the engine RPM at cruzing speed at the torque peak of the engine. This is the spot where BSFC for the engine is the lowest (best spot for economy).
My 1987 1 don reg cab dually would knock down 11 mpg with a 454 tbi highway speeds of 70 mph with a th400 and 3.73 gears although I had smaller than stock rear tires at the time.
I have heard from many people that after they do a over drive swap that the OD is to tall and the engine bogs. This statment makes me bieleve that you should look at the hole system to optimize drive train for the engines powerband inorder to get the best Fuel mileage.
For refrence most of the diesel (cummins) guys the peak torque rpm is aproximately 1800 rpm so they gear to have close to that rpm at cruse speed to maximize fuel economy. I know a BBC has a much hirhger (RPM) torque peak than a cummins so draw your own conclusions.
My .02
Hope this helps.
As stated before the ecomnomics of the change are dependant on the reasonably expected increase in fuel economy so if you were getting 11 mpg before what new mpg would you need to pay off the conversion given the highway mileage you use and the time you want to recover your money in (at current fuel costs), this is (ROI) return on investment.
Now that I have stated the obvious are you looking for what others have gained in fuel economy to help you calculate your ROI?
Wow that was alot longer than I thought when I started this reply!!!
Chevyman350 is offline   Reply With Quote
Old 12-17-2012, 06:01 PM   #7
JCampbell
What size tires?
It’s not so much a "return on investment" that I’m looking for, in as much as I just want to get this thing back on the road without having to reinvent the wheel. For me 1-2 MPG isn’t enough of an increase to suffer through the added time/cost/headaches.
Old 12-10-2012, 08:45 PM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
My 454 TBI truck with factory 4L80E and 4.10 gears never once exceeded 10 miles per gallon ever. That's 100 percent perfect tune and driven quite conservatively. You're already ahead of the curve at 11 mpg. Without putting pencil to paper, I'd estimate you'd need to drive it about eleventy trillion miles to recoup the conversion costs with what you have now. Even if it got you a solid 2 mpg increase, how long would it take to get your money back ?
Tx Firefighter is offline   Reply With Quote
Old 12-10-2012, 08:47 PM   #9
JCampbell
Yeah...that's kinda how I'm leaning.
Old 12-17-2012, 07:08 PM   #10
INSIDIOUS '86
INSIDIOUS '86's Avatar
You guys also got to look at the amount I wear it cuts down on an engine as well. Lower rpm on the hwy is less engine wear. IMO if the trans don't pay for itself still its at least worth the comfort to me just knowing that driving across state lines won't cost so much
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 12-17-2012, 07:18 PM   #11
68Timber
I know the pieces fit
68Timber's Avatar
I'm struggling with this on my 79, rebuild my TH350 or upgrade to a built R4. I'll be at $450 or so just on the converter either way. I only drive this truck for fun, weekends mostly, and don't need it to go down the highway. I want an R4 but don't need one.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 12-17-2012, 07:47 PM   #12
JCampbell
The other thing I considered is that the cost to rebuild a 4L80e is substantially higher than a TH400.
Old 12-17-2012, 07:53 PM   #13
68Timber
68Timber's Avatar
And the 400 will likely only need to be built right once in the next 20 years.
John
74 Honda Z50 build
Old 12-17-2012, 08:34 PM   #14
Firebirdjones
Yup, 400's are cheaper to build.
I decided to bite the bullet and do the swap but went a much easier route.
I had the 4L80E here and decided to do a gear vendor instead. You can figure about a 30% increase in mileage, not alot if you are getting 11 mpg now. But I also like the RPM decrease, less wear and tear on the engine, less noise.
It also turned the trans into a close ratio 6 speed, great for pulling the 10,000 lbs trailer from stoplights, and it can be engaged while towing on the highway to drop rpms as well, something that you can't do with the 4L80.
Besides, you'll find once you get into the swap (because I did) that installing a fresh 4L80, controller, driveshaft, torque converter, you'll be almost exactly right on the price of a gear vendor unit, and still only have a 3 speed trans, with an overdrive you can't use when you tow.
Firebirdjones is offline   Reply With Quote
Old 12-17-2012, 08:36 PM   #15
SCOTI
SCOTI's Avatar
A 4l80e & th400 would be the same as far as longevity after rebuild since they're basically the same trans (minus the electronics & OD).
Exactly why I opted to stick w/the th400 (not enough difference to justify the expense of swapping). I also looked into the GV unit but decided against those as well because of cost & complexity for uneducated users (RideTech used one on their 48hr Camaro & destroyed it by simply overlooking it being engaged when someone put the car into reverse. It mucked something up & ruined the unit).
What I do like about the GV was the under & over drive capabilty. But if car guys can mess one up like that, it makes one hesitant. Cost of a new unit is on par w/the 4l80e rebuilt so they're a wash. Now, if you could find a GV unit that's used but in good shape, it might be a worthy swap.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-17-2012, 08:46 PM   #16
Firebirdjones
Any overdrive swap done correctly gets pricey.
Just depends on how much you use that particular vehicle as to whether it's worth the expense for anyone.
I never was looking for gas mileage increases to pay for the swap I just wanted less wear on the engine (engines are getting expensive too ) Less noise makes the drive pleasant, but I think I'm starting to get old.
It doesn't hurt that I can get close to the mileage my neighbor gets in his 03 duramax in my dinosour 79 1 ton with a 502, so I'm not complaining.
Old 12-18-2012, 03:03 AM   #17
KQQL IT
At the body shop.
KQQL IT's Avatar
My vortec 7.4 does 10/12 454 4L80 4:10 and 31" tires. Crewcab short bed single rear.
Years ago did a doug nash o/d on a '86 1 ton with 454 and a quadrajet weighed 8500# before we "over"loaded it and it did 10/12.
We also had an 89 with tbi and it got worse mpg's than the 86 did same application.
Old 12-18-2012, 03:11 AM   #18
Redcap
I'm planning on using one of these Ranger Overdrive units in front of the SM465 in my K20.
Redcap is offline   Reply With Quote
Old 12-18-2012, 03:19 AM   #19
cal30_sniper
cal30_sniper's Avatar
I can shed some practical light on this topic, as I've been working over the same issue during the last year, and have actually had time to really weigh some of the benefits/detriments of an overdrive swap in one of these trucks.
I've got an '86 C20 Suburban, that was a factory 454/TH400 combo with 3.73 gears. I've been running 265/70/17 all terrain load E tires (32.7" tall). After a good tune and clearing out all the emissions junk from under the hood, I pulled down a best of about 12.5 mpg at a steady 60-65 mph cruise. The factory TH400 was doing just fine, but I had a stout TH700 in my wrecked '90 burb, and figured I'd try the swap, since it would only cost me a couple hundred bucks and time, I might pick up some gas mileage, and I knew the history of the trans. I wasn't hoping for much mileage, and my main motivators were to drop engine RPMs on the highway, add the lock-up torque converter, and switch the 75k mile TH400 out for a 20k mile TH700 with a +3 qt pan, B&M Traveler torque converter, B&M shift kit, B&M lock-up controller, and some other goodies that I put in it.
When I did the swap, I also added Doug-Thorley tri-y headers and had a 2.5" h-pipe dual exhaust system and magnaflow mufflers built for it. After some tuning (with a wide-band O2), I got a best of 14.2 mpg at a 70 mph cruise. I normally average around 13mpg with mostly highway driving, and 10-11mpg with mostly city driving now. That's a benefit of about 15% increase in fuel economy at a faster speed. With the TH400, every mph above about 65 rapidly ran my mileage into the toilet. I can easily cruise 75-80 mph now and still average around 12mpg.
The gas mileage increase is nice, but dropping several thousand dollars on a gear vendors or 4L80e setup will never pay for itself. As far as engine wear, keep in mind that even though your spinning the engine slower, it's under more load. Furthermore, the overdrive adds in a much larger danger zone for pinging. Low engine speed and high load is very conducive to detonation, and it can do severe damage to your engine. You have to be conservative with your timing and watch your AFR in situations where the torque converter is locked and you are below 50mph or so in 4th gear. On a separate note, even the warmed over 454 can be a little lacking in the torque department below 65mph. In 4th gear, with 3.73s and a 32" tire, you're only turning about 1800-1900 rpm with the converter locked up. The motor is much happier in the 2200 rpm and up range, but you start dealing with significant wind resistance at those speeds, which is always going to kill mileage in these trucks.
I might see a little better mileage by swapping to 4.10s, but it wouldn't ever pay for itself in cost and labor to do that. When the 454 I have starts giving me trouble, I plan on building a mechanical fuel pump Gen VI block with some good heads and a very mild roller cam. That should take care of my torque problems down low and bring the highway mpg up a bit.
I did the TH700 because I had one already set up for a suburban, and it was a fairly easy swap. The lock-up converter drops trans temps a lot, and with a good shift kit and top quality fluid/cooling, the TH700 will live up to any reasonable driving expectations behind an engine that's not too wild. I've beat on mine pretty hard behind the 454 before, and never experienced even the slightest hint of a problem from it. That low 1st gear also works great for crawling up really rough mountain roads.
I don't think I would even consider the 4L80e swap. I don't like the whole idea of the electronic controller. Sure, it's nice for tuning, but it's one more black box to go wrong that I wouldn't be able to fix on the side of the road. Ditto on electric fans/relays. I like the simplicity of the TH700. A TH400 with a gear vendors would do the same thing, just with a bit less overdrive and no lock-up converter.
Sorry if that's a little long-winded. Hopefully you can pull some good info out of it. If you're looking for it to pay off, don't do it. If you're looking for increased driving pleasure, I recommend it.
86 Chevrolet K20/30 Suburban - 8.1/NV4500/NP205/Dana 60/14 bolt FF, build in progress
73 Formula - 400/Doug Nash 4+1, resto on hold
86 Chevrolet K30 3+3 - 350/TH400/NP241, Air Force/Forest Service Rescue Truck, for sale
01 Ram 2500 - 5.9L Magnum, daily driver
91 BMW 325i - Chumpcar series racecar
cal30_sniper is offline   Reply With Quote
Old 12-18-2012, 03:41 AM   #20
KQQL IT
At the body shop.
KQQL IT's Avatar
^^^ smiles per gallon. Always thought that was the reason we do this.
My 73 with a 850 double pump holley big cam and a sloppy 4k converter 3:82 geared is by far my favorite to drive...
Old 12-18-2012, 03:49 AM   #21
Ford Assassin
Ford Assassin's Avatar
I get 13-14 mpg in town, 18-19 mpg highway in my K5, I have a built 4L80e w/a billet 3600 stall converter and its been hassle free from the word 'Go'.
Keep in mind this with a supercharged engine driven by a guy with a heavy foot.
Details in my sig....
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 12-18-2012, 11:46 AM   #22
cal30_sniper
And you've got a significant mpg advantage in nearly every respect. He'll never be able to come even close to that kind of mileage with a 1 ton unless he does a diesel swap. You're using a LS based engine, with all the advantages that go along with that (including computerized engine controls, I assume). It's fine for a light K5, but would be a gas drinking hog in a 1 ton. In fact, that's where almost all of your increased town mpg comes from. That 2wd K5 is literally thousands of pounds lighter than a big block 1 ton truck or 3/4 ton sub.
You've got some real advantages on the highway too. Your 3"/5" drop means that you're pushing much less air. If you lifted it back up to factory height, I bet you'd see about a 2mpg drop right off the bat. You're also running low-profile street tires. If you were running anything close to the factory tire diameter and weight, and you'd lose more mpg. The low profile tires and lightweight truck allows you to run 3.42 gears. He'll never get away with that in a 1 ton with full size tires. More mpg lost. Your 10 bolt rear is also less of a power drain than the gargantuan 14 bolt that he likely has under his truck.
Overdrives make much more sense in small, light cars (which your K5 is bordering on). This is where you see the claims of a 25 or 30% mpg increase. They're not pushing much air, they've got small engines, and their light. The same recipe does not work in a heavy truck. You drop engine RPMs, but the engine has to work much harder to produce enough torque to keep that weight rolling at the lower RPMs. That's why you don't see much mileage on the highway. You'll never see good mileage with a big inch motor in a heavy truck around town. The overdrive has no impact on mileage at all below 45-50 mph.
Old 12-18-2012, 12:06 PM   #23
Ford Assassin
I never claimed it was an apples to apples comparo. He asked, I answered.
My tire diameter (275/40/20 or 28.8") is actually about an inch taller than factory tires (225/75/15). Also my 20x8.5" & 20x10" wheels weigh alot more than factory 15x7" steelies.
I didn't choose the 3.42 gears, in fact I am going with either 3.90 or 4.11 gears (along with a custom 9.5" 14 bolt) in the next few weeks.
Mine isn't a daily driver anymore, I just like the OD so I am not spinning the engine to the moon when cruising down the highway.
Cable
Old 12-18-2012, 12:05 PM   #24
cal30_sniper
Another aspect of the TH700 to keep in mind is its extremely deep first gear, and corresponding really long 1-2 shift. Everybody talks about it like its some sort of performance plus to have that really low gear. Other than rock crawling or towing an extremely heavy trailer (which you really won't be doing with a TH700 anyway), it's more of a nuisance than anything. The 1-2 drop really lugs the motor, it was much smoother driving the TH400 around town than the TH700. The 4L80e doesn't have that problem, but it also costs much more, has no provision for a mechanical speedometer, and requires a very expensive dedicated electronic controller unless you're running an LS motor PCM. I'm sure the controllers are reliable, but someday one is bound to give out. If you happen to be that unlucky person, you won't be able to diagnose the problem, nor will you be able to walk into an O'Reilly's wherever you're stranded and order a replacement. Your vehicle will be down for quite a while, not good if you use it as a DD or for a lot of road trips.
For the money spent, you'd be much better building a bulletproof TH700 (~2k) or putting a gear vendors on your TH400 (<1.5k if you watch for a while and find a good deal used). Why spend 2-4k on a good 4L80 setup when a comparable transmission can be had for less money without all the electronic controllers? If you want the best of both worlds, build a TH200. You'll have the lockup converter and overdrive of the TH700, with the gear spacing of a TH400.
Old 12-18-2012, 12:33 PM   #25
Firebirdjones
I'm thinking everyones situation calls for a different approach. The 700 works for you, but that's not a trans I want in my tow rig. With a combined 15-16,000 lbs. to pull around I don't trust that trans, not to mention that 1-2 gear spread is absolutely horrible, I couldn't stand leaving red lights with that setup yanking all that weight.
However I recently built a 4L60E to put behind a 6.0 in my blazer, to hold 600HP and quickly spent $1500 on the trans alone. So they aren't exactly an economical swap either. Works fine in my blazer, but I still wouldn't use it in my 1 ton truck.
The 502 in my 1 ton dyno'd at 540 ft lbs. with a very flat 500 ft lbs. curve from about 2600 to 4700 rpms. So it yanks the trailer around even at low rpms very easily, even with the overdrive engaged isn't a problem, which is why I went with Gear Vendor, can't tow in overdrive with a dedicated 4 speed auto overdrive.
I also specifically did the Gear Vendor on the back of the original 400 turbo because I didn't want a lockup converter with this setup. I hate towing with a lockup converter, they constantly kick in and out and drive me nuts even when pulling in 3rd gear. I pull too much weight to deal with that. With the gear splitting ability it's also now a close ratio, it acts like the allison trans in my neighbors duramax. The 400 is still one of the toughest trouble free transmissions that GM built, and the Gear vendor is good for 1500 HP, it's a tough combo that won't break. Just alot of reasons for me that make this combo perfect for the intended use of my truck.
Reliability isn't a really big issue with the electronic stuff. The electric motors on the fans can be bought most anywhere (that's why I use GM stuff ) The electronic transmissions have been around long enough that most all the bugs are worked out. There really isn't anything on my vehicles that I can't repair with relative ease on the side of the road.
I agree, I love simplicity, some of my cars still run points and I'm fine with that. But when you want gas mileage and efficiency, sometimes that simplicity will have to be put asside for some modern tricks. Just how far you want to take it is the question. Lots of mileage can be found other ways before that overdrive goes in.
