Old 12-13-2012, 07:48 PM   #1
BMERDOC
BMERDOC's Avatar
Need Blazer Tub Pics!
Does anyone have close up shots of the area behind the front seat on a Blazer tub? Underneath and inside would be great. Isn't it stepped there? Is there a replacement panel for that area? Is the front floor board the same as a truck? Thanks in advance!
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 12-13-2012, 08:03 PM   #2
Nobby
Nobby's Avatar
Re: Need Blazer Tub Pics!
I got a couple pics. I'll have to search for them tho..Heres a couple from when I put a truck floor in my Blazer..
Nobby is offline   Reply With Quote
Old 12-13-2012, 08:06 PM   #3
Nobby
Nobby's Avatar
A few more
Old 12-14-2012, 12:04 AM   #4
BMERDOC
BMERDOC's Avatar
Thanks! So the Blazer floor isn't the same but a truck floor will go in? Is that verticle piece between the floor and bed available in the aftermarket?
Nick Carter
Old 12-14-2012, 09:06 AM   #5
Bentblazer
Bentblazer's Avatar
If I remember correctly the floor will work but the area right at the point where it meets the vertical frame at the start of the bed floor will need some work. As far as the vertical piece I dont think it is being reporduced but is easly made. I had to make mine along with the mounts that hold the frame bolts.
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
1930 Chevy two door rat
Bentblazer is offline   Reply With Quote
Old 12-14-2012, 10:01 AM   #6
fxdxharley
Just a nother gear head
fxdxharley's Avatar
the fllor are the same to just behinde the seat mounts then thats where they are different. the truck floor works great just needs to be modified to make the lip at the vertical raise to the bed area. that vertical piece isnt available but is easly made. for the most part all truck parts work in the blazer with some or no mods depending on the peice. i think there is some pics from underneath in my build thread link in my sig.
2013 HD FLHX
2000 chevy 2500 6.0l 4x4 3dr
2000 harley fxdx
71 Jimmy 4x4- future crawler/ woods rig
71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589
fxdxharley is offline   Reply With Quote
Old 12-14-2012, 07:39 PM   #7
David623
I am doing the same as you, I purchased a floor for a cab and going to cut to fit, it looks as I be cutting about 10 inches of the back,basically where the gas tank would fit in the cab. I fabricated the vertical piece, just enough of the old part I was able to get dimensions.
David623 is offline   Reply With Quote
Old 12-14-2012, 07:40 PM   #8
David623
Here is some pictures I still am not good at posting things.
Old 12-14-2012, 07:44 PM   #9
David623
Here I think I got these pic posted
Old 12-17-2012, 05:46 PM   #10
lampltr
David,
Where did you get the wheel dollies? That's kickin!!!
Will need something similar for mine as she is a bare to move around by oneself LOL
How much weight can these support?
Thanks!
Pat
lampltr is offline   Reply With Quote
