Old 12-14-2012, 07:37 PM   #1
70chevy10
70chevy10's Avatar
i am looking to do a lift and 33s on my 72 c10 any ideas?
hi I am thinking about going a 3in body lift and 33s on my 72 I was wondering if any of yall would have any pics of that set up.
1970 c10 LWB (BIG BUILD UNDERWAY) SEMA 19?
1969 GMC K2500 V6 Step Side Long Bed
2008 F250 650hp CUMMINS SWAPPED Daily Driver + too much to list
LAST DROP GARAGE, LLC.
Check the Shop out!
http://www.lastdropgarage.com
70chevy10 is offline   Reply With Quote
Old 12-14-2012, 07:49 PM   #2
Dunenutt
Newbee
Dunenutt's Avatar
Re: i am looking to do a lift and 33s on my 72 c10 any ideas?
A body lift causes a multitude of issues, some are safety related. To lift a 2wd 3" takes some serious fabrication. A much better option would be to just live with some 31's, and consider a 4x4 for the bigger meats.
Dunenutt is offline   Reply With Quote
Old 12-14-2012, 08:52 PM   #3
70chevy10
70chevy10's Avatar
I would do 4x4 if i could but how about a 2 in would that cause as many problems?
Check the Shop out!
Old 12-14-2012, 08:58 PM   #4
70chevy10
70chevy10's Avatar
here the truck is.Name:  IMAG1890.jpg
Check the Shop out!
Old 12-16-2012, 02:44 PM   #5
72MARIO
72MARIO's Avatar
I have 3" fabtech lift springs and a 1" ball joint spacer on my 1967 C20. My moog upper ball joint has 10,000 miles and its shot. I have been running 285 75 16. They just cleared some timed touched the front bottom of fenders. Mainly hwy 200 miles round trip. Nice roads. I have tracked down a NAPCO longhorn. That's the frame that will be going under my body. I would stick with with 31s.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 12-16-2012, 03:00 PM   #6
dlh760
dlh760's Avatar
Don't know if it helps or not but my 68 c10 at stock height with worn shocks will clear 33x12.50r15s with no rubbing . I was curious as to how big of a tire would fit so I swapped front to rear and turned it fully lock to lock while having someone else bounce the front end and had no rubbing issues at all.hth Dan.
68 Chevy c10 longbed 307 with 305 H.O. heads,edelbrock performer intake,edelbrock performer plus cam,hei,Holley 650 double pumper and th400. Daily driver. It hauls butt,it hauls my butt where I need to go
dlh760 is offline   Reply With Quote
Old 12-16-2012, 08:42 PM   #7
70chevy10
70chevy10's Avatar
Ya my 1970 c10 does to but I am looking for a more lifted stance on my 72Name:  100_4860.jpg
Check the Shop out!
Old 12-16-2012, 09:49 PM   #8
BiggSixx1970
Just my opinion, and I don't mean to be abrasive. But, lift has no business being on a 2wd, and tires that big have no business being on a 2wd. If you wanted a mudder, you should have got a 4x4. Bigger tires = bigger tire shop bill. These trucks already handle like an old school bus, so jacking the front end up isn't going to help that any. I'd level it out, but I wouldn't lift it..
Buuuut it's your truck Do what you want with it, I'm just more about "go" instead of "show". You try taking that thing off road, even with 33''s and lift and you'll just bury it that much deeper lol
1970 C20, SM465, Eaton Ho52, HD coils, NO PB/PS/AC, 250 I6, Wood bed. All original minus a tune up!
http://67-72chevytrucks.com/vboard/s...d.php?t=545486
Gentlemen wear a bow tie.
BiggSixx1970 is offline   Reply With Quote
Old 12-16-2012, 10:42 PM   #9
nightmare
nightmare's Avatar
You could replace the C10 springs with some C20 springs. This would net about 2". You don't have to replace anything else either.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 12-16-2012, 10:52 PM   #10
71K20chevy
71K20chevy's Avatar
Not exactly 3", but here's my '71 with a 4", but once I get my fat butt into it it's probably 3"
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 12-18-2012, 05:47 PM   #11
70chevy10
70chevy10's Avatar
Thanks thats a good idea with the springs. Nice truck 71k20chevy.
Check the Shop out!
Old 12-18-2012, 06:37 PM   #12
nate_g_2003
nate_g_2003's Avatar
With the age of these trucks, I'd imagine you'd have a hard time finding a body lift kit that would work. Stick with a suspension lift, if you really have to raise it up. Avoid lift blocks. Spend the money and get new springs for the rear, and new coils up front.
-Nathan-
1972 GMC K2500 Suburban "The Project"
2013 GMC Sierra 1500 SLT Z71 "The Daily Driver"
2005 Ford F150 Lariat SCrew 2WD "The Daily Driver" SOLD
1995 GMC Sierra C1500 SLE "The Daily Driver"SOLD
2003 Ford Ranger Edge 2DSC 2WD Flareside "The Daily Driver/Project"SOLD
nate_g_2003 is offline   Reply With Quote
Old 12-18-2012, 06:49 PM   #13
rebel son
I agree spring lift is the only way to go. I know this is overkill for what you are looking to do but I used springs only on my 62
rebel son is offline   Reply With Quote
Old 12-18-2012, 06:49 PM   #14
70chevy10
70chevy10's Avatar
i will look into it thanks for the advise
Check the Shop out!
