12-15-2012, 11:12 PM | #1 |
tach cluster 1976 -77
pulled from a 76-77 half ton truck. 60 lb mechanical oil gauge. i`ve not tested it , but gauges appear to be in working condition. includes the harness, needs a new end on the ground wire. the housing has a few cracks and is missing the tab on the left. $150 shipped
12-21-2012, 07:22 AM | #2 |
Re: tach cluster 1976 -77
ttt
12-30-2012, 09:17 PM | #3 |
was able to check the tach , it works but reads high. new price . $120 shipped
12-31-2012, 10:35 AM | #4 |
Hey Woody we just bought a 1975 crew cab dually 454 camper special but know very little about 73-80 trucks. What is the difference between 73-75 gauge cluster and the 76-77 you have listed?
Always appreciate you , Thanks Paul and Jason
You can shear a sheep every year, but you can only skin it once The person dealing with facts is never at the mercy of the person dealing with theory 1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn 1975 Silverado 454 Crew cab camper special dually |
12-31-2012, 06:05 PM | #5 |
73-75 have an Amp meter and the configuration of the plug going into the back may be different...but im nto totally sure when i put a 77 tach cluster in a 73 i had already swapped the harness for a 77. and my tach reads high too. the one in my 74 is the correct one for a 73- 75 and it is spot on...
hope that helps
67/68 K/20 "The BEAST" 68 K15 V6 LWB. 73 K20 GMC Burb "The Bomber" 74 K/5 74 K20 Custom Deluxe 86 K10 Shorty 92 K2500 Burb 95 K2500 GMC Life is what you make it Live each day like it was your last Old GM Trucks never go out of style |
12-31-2012, 08:57 PM | #6 |
You can adapt the ammeter harness to the voltmeter cluster but it is a bit of work ...use the newer plug and splice 12 v + to the voltmeter
Often reading high can mean the tach was in a 6 cyl originally ...will work fine but 25 percent high |
01-02-2013, 08:45 PM | #7 | |
I believe there is a calibration resistor in a lot of 70's GM tachs that has a tendency to change value with age and cause them to read high. Here's a page showing how to fix 1978-up truck tachs --> http://howtoalmanac.com/kevin/projec...chfixtruck.htm I think the internal circuit on the 76-77 tachs is slightly different but still the same concept. Last edited by ray_mcavoy; 01-03-2013 at 06:47 PM. |
01-02-2013, 09:33 PM | #8 |
here`s a pic of the backside of the tach
01-01-2013, 04:02 AM | #9 |
If that is a 6 cyl tach , iam interested. Any way you can confirm? Thanks, al
Al from Calary. 72 Chev S/B Ground Up Project. |
01-01-2013, 10:05 AM | #10 |
The truck i pulled it from is a 76-77 3/4, V-8 4spd. GMC. but that doesn`t mean someone didn`t change it out at sometime.
most of these that i`ve seen will have 8cyl stamped on the back , this one doesn`t, it has a four digit number (8775) i`ll try to get a better pic of the tach later today. |
01-03-2013, 04:45 PM | #11 |
I'll go $100
4oldcars Driving: 1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado The ones I let go: 1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed |
