Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 12-15-2012, 11:41 PM   #1
D6c
Replacement for split rims on C60?
New to the forum, so this may be asked many times before.
I've got a '66 C60 that I use for a grain truck that has the original 20" split rims. Tires are getting pretty old so if I replace them it would be nice to change wheels too. I can still get one tire shop to work on the split rims, but they don't like it very much.
Found Accuride wheels (p/n 28160) that are 22.5", but the dealer quoted me $400 ea x 6....way more than the truck's worth.
Are there any later Chevy/GMC trucks that have tubeless wheels that will fit?
(10 hole, 8 3/4" Bolt circle, 6 1/4" bore...uses flat face flanged cap nut)
D6c is offline   Reply With Quote
Old 12-16-2012, 12:27 AM   #2
travz500
travz500's Avatar
Re: Replacement for split rims on C60?
I may be able to hook you up We are in northeast ks in ozawkie we have one sitting around with a bad motor it has the 10 hole 22.5 wheels and good tires on all 6 wheels let me talk to my cousin I know he wants to sell them pm me if you interested I think the drive tires are almost new
travz500 is offline   Reply With Quote
Old 12-16-2012, 12:31 AM   #3
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Do you have a truck tire shop around that may have some laying around?
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 12-16-2012, 01:53 AM   #4
Captainfab
60-66 Nut
I'm not sure what year they changed, but the newer C50-60 size trucks have a larger hub bore and a larger bolt circle. I know my '89 GMC 7500 has the larger bore and bolt circle. I don't know if you can get the load rated tires you will need, but you might look into the 19.5 wheels. They are common on the heavier motorhomes, as well as a lot of medium duty trucks.
Old 12-16-2012, 02:09 AM   #5
travz500
travz500's Avatar
the ones i got are on a mid 80s truck had a 24' box on it delivery truck for a rental company I think will do some measuring tomorrow
Old 12-22-2012, 11:51 AM   #6
factorystock
factorystock's Avatar
It appears you have the Chevy 10 lug system not the larger Budd 10 lug system. The Chevy 8 3/4 bolt diameter was used on the light duty 60 series, while the heavy duty 60 series used the Budd 6 lug or Budd 10 lug system. In this case, it would be cheaper and less time consuming to just have newer tires put on your existing rims at a truck tire dealer only business. One piece 22.5" Chevy 8 3/4" 10 lug wheels are out there, but not easy to find.
factorystock is offline   Reply With Quote
Old 12-22-2012, 12:02 PM   #7
factorystock
Here is a photo of a one piece tubless 22.5" Chevy 10 hole 8 3/4 bolt pattern. Some models used 5 lug front 10 lug rear, some models and 10 lug front and rear.
Old 02-18-2022, 03:19 AM   #8
cnntnsxty@aol.com
Anyone know a source for wheel studs for a 75 C60? The rims I found are a little thicker than stock and lug nuts won't cover the stud, about 1/4 inch too short.
cnntnsxty@aol.com is offline   Reply With Quote
