Old 12-16-2012, 07:08 PM   #1
Biggs1966c10
Heat and sound sheild?
any suggestions on what to use i would like to do floor and inside of doors
Biggs1966c10 is offline   Reply With Quote
Old 12-16-2012, 07:16 PM   #2
TxRat
TxRat's Avatar
Re: Heat and sound sheild?
I used this in my 57 Nomad and so far its holding up quite well. It was around $10 for 4"x33' roll. took two rolls to do my car. I'd imagine one roll could do a truck.
TxRat is offline   Reply With Quote
Old 12-20-2012, 12:20 AM   #3
FetchMeAPepsi
FetchMeAPepsi's Avatar
Are you saying this is a good replacement for Dynomat?
The price difference is staggering.
If so I'll be ordering some today.
Step by steps:
Remove primer to reveal original paint
Rebuild a carburetor
See My Build - Cecilia!
Some people are like slinkys. Not worth much but funny as heck when pushed down stairs.
FetchMeAPepsi is offline   Reply With Quote
Old 12-21-2012, 10:52 AM   #4
TxRat
TxRat's Avatar
Its been in my Nomad with long headers for the whole summer with no issues. No smell, problems at all...
I'm repairing the floor in my 66 and will putting this product down on the floor of it prior to carpet.
Its been good stuff so far...
Old 12-20-2012, 07:13 PM   #5
boucher racing
boucher racing's Avatar
I have both products, the Lowes peel n seal is thicker. I did my whole cab, it was great, effective and inexpensive.
Build Threads: "JED" 66 GMC C1000
http://inliners.org/ubbthreads/ubbth...1857#Post61857
"Cropwell" 66 C10
http://67-72chevytrucks.com/vboard/s...d.php?t=587639
boucher racing is offline   Reply With Quote
Old 12-16-2012, 07:28 PM   #6
62 Barnfind
62 Barnfind's Avatar
Where did you get it? I am looking at other options also.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 12-16-2012, 07:36 PM   #7
TxRat
TxRat's Avatar
I found it at Lowe's or Home Depot. Both stores carry it...
I put it in at the beginning of the summer. Long tube headers and no A/C. brought the interior temps and noise from the exhaust down..
Old 12-16-2012, 07:44 PM   #8
brokenspoke
brokenspoke's Avatar
Does it smell?
brokenspoke is offline   Reply With Quote
Old 12-16-2012, 07:58 PM   #9
TxRat
TxRat's Avatar
Originally Posted by brokenspoke View Post
Does it smell?
Not one bit. That was a big concern of mine but none at all...
Old 12-16-2012, 08:09 PM   #10
62 Barnfind
Used the wrong quote.
John Z
62 Barnfind
Old 12-16-2012, 08:10 PM   #11
62 Barnfind
Thanks man, Is that all u used or did you use the sound felt also? I am going out tomorrow and getting a roll. You said one roll will do a single cab all the way behind the gas tank?
John Z
62 Barnfind
Old 12-16-2012, 08:17 PM   #12
TxRat
TxRat's Avatar
The rolls are 33 feet long so it should, I did a my Nomad with two rolls. It's cheap so incase you waste some of it I would buy two rolls, The carpet I used had the jute attached to it...
Cut it into manageable pieces and be ready for it to stick when it lays down. It is very sticky...
Old 12-16-2012, 08:26 PM   #13
62 Barnfind
Thanks again!
John Z
62 Barnfind
Old 12-17-2012, 01:05 PM   #14
theastronaut
theastronaut's Avatar
I'll second the Tite Seal or Peel and Seal stuff from Lowes or Home Depot. I've used it in doors a few times and it makes a lot of difference.
theastronaut is offline   Reply With Quote
Old 12-17-2012, 05:05 PM   #15
wayno
I would have never guessed - gonna have to check it out since if I'm not in the parts store I'm in one of those two places lol
wayno is offline   Reply With Quote
Old 12-17-2012, 05:37 PM   #16
jimmydean
jimmydean's Avatar
Just make sure you use a seam tape with peel and seal. When I did mine, it got hot before I covered it and I got black crap on some of my stuff. I seam taped everything and it's perfect now.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 12-17-2012, 06:40 PM   #17
kieth
kieth's Avatar
I used 2 types from Home Depot on my truck,
1. 6-8" wide butyl rubber with aluminum covering (very much like Dynamat) this takes the boom boom out of the large floor paniels ) but I could not find it yesterday at home depot....will go online and lookkk...again
2. the other product was at home depot called frigi king and it was very similar it was a closed cell gray insulation with adhesive on the bottom and aluminum on the top, they still have that.....
I put the butyl rubber down first then the insulation on top of that...my truck is quiet as a church mouse........will look for the numbers......Kieth
I also used the seam tape....cost of each product was about $ 1.25 per sq ft..
here is the insulation still cannot find the butyl rubber/alum coated flashing
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
kieth is offline   Reply With Quote
Old 12-17-2012, 07:49 PM   #18
TxRat
TxRat's Avatar
Hmmm, I didn't have this problem. But, that's good insurance...
Old 12-17-2012, 09:08 PM   #19
jimmydean
jimmydean's Avatar
It was where the floor meets the kick panel on mine. I had my newly upholstered kick panel sitting in place on the bare seam. It wasn't a huge issue, but I ended up seam taping the whole deal just to be safe.
I have a foam mat between the peal and seal and carpet, so it wouldn't ever hit the carpet, but it looks a lot cleaner seamed up, too. Not that anyone sees it under the carpet
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 12-17-2012, 07:30 PM   #20
Hx16457
Hx16457's Avatar
I too, use the lowes peel and seal, no smell with it either. However I laid it in the colder months, so I used a torch lightly to heat it and used a small wooden roller to press it down. It is stuck down now! Haha
As for inside the doors, (google micro balloons) I bought that and mixed it with white latex paint (1 quart did both doors), pour half the paint into a container with a good lid. Mix in about the same amount of micro balloons and stir it up. Then paint the empty insides of your doors! Be careful to leave your drip holes open!
It's cheap and works great to deaden the hollow sounding doors!
People who make excuses didn't want to do it in the first place!
http://s1326.photobucket.com/albums/...cpZZ1QQtppZZ16
Hx16457 is offline   Reply With Quote
Old 12-19-2012, 09:25 PM   #21
62 Barnfind
I bought two rolls today. One only did 1 1/2 of the floor. Hopefully I will finish it tomorrow and I will post a pic.
John Z
62 Barnfind
Old 12-20-2012, 08:25 AM   #22
rustyescott
rustyescott's Avatar
i have used it in my diesel dually, it helped a bunch.
rustyescott is offline   Reply With Quote
Old 12-20-2012, 02:14 PM   #23
Snowbound
Snowbound's Avatar
Anyone have a source for a similar product in Canada, post it up. I searched every building supply and HVAC and roofing supply company here, and no luck.
Closest I found at Home Depot was Blueskin membrane, but no foil on that.
1965 Chevy Short Box Stepside, 230 - 3 speed, 4:11 gears, original paint rust free survivor. Now sporting a 383 SBC and TKO-600
Snowbound is offline   Reply With Quote
Old 12-20-2012, 06:53 PM   #24
FetchMeAPepsi
It's available on Amazon here
Step by steps:
Old 12-21-2012, 01:36 PM   #25
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I used similar stuff in a slightly larger role. Its about half as thick as dynomat, and the one I used did not have the reflective coating, but I didn't mind because I chose to run an automotive insulator on top of it. It give the firewall and floor a very thick/solid feel.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
