I'm in the middle of sanding my 70 c10 frame getting it ready for por 15 do you guys have any tips
Posted via Mobile Device Posted via Mobile Device |
Re: Any tips for por15
spray it, dont brush it. brushing leaves stroke marks.
The Older Generation
I don't know where you are getting your POR15 but I have done 2 frames with it using a brush and it dried as smooth as glass. No brush marks what so ever.
It also goes farther if you brush it. I did my frame with less than a quart. (one coat) I paid $32 a quart for mine at a swap meet.... I think this is a good product but I think the jury is still out on the longevity. One of my questions is whether rust will start creeping under it around the bolt holes and areas where you can't get full coverage with it. I have to spend a little time here on my observations of the POR15 product. First off if you have never used it and you are thinking about it I can't stress enough to read ALL of the instructions, TWICE. Being old school I have to learn all lessons the hard way. Two important points, #1- Wear some "good" rubber or latex gloves. (don't wear the ones you got from your buddy over at the ambulance barn, or that cute nurse at the hospital, they aren't heavy enough) If you don't wear gloves when you apply it you can wear them three weeks later when you go to Uncle Harry's funeral, to cover the POR15 that's STILL on your hands. #2- If your bestest buddy Paul, (you know the one that's always pulling your leg about something) tells you to put a piece of Saran Wrap between the lid and the can after you have used some out of it don't say "yeah, right", do it! Otherwise you'll end up having to cut the center out of the lid with tin snips and pour what's left in the can into a jar. If there is any paint residue around the lip of the can and it sets a week or two you will NOT be able to get the lid off of the can, period! Oh, and another thing, if you wear coveralls to protect your best pair of pants and you drip the paint onto the coveralls they will now be your second best pair of pants. You will not be able to wipe the drip off before it soaks through to your good pants. I almost forgot.... If you get it on any threads that you have to get a nut or bolt on/off of plan on using a tap, die, or thread chaser to clean the threads up first. Oh, and still one more thing, be sure and put two coats on it if you are not going to top coat it. Hope this helps..... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 12-17-2012 at 11:24 AM. |
I prefer Rustoleum.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
#5 | |
72 GMC
excellent advice. the one other thing i saw on tv recently is that butane is heavier than air. this stuff starts curing as soon as you open the can. if you dont use the whole can, lightly spray some butane in the can to displace the air before you seal it. it helps the shelf life a lot. |
i never ever remove the lid on a can of POR15
i drill two small holes in the lid one to pour and one for a vent// use sheetmetal screws to seal the holes after you have poured out what u need to use that time it prollongs the life of the product and if they sealup so tight that u cant remove drill twonew holes and two new screws if you want to topcoat the POR15 for a finished final product// i spray topcoat over POR15 when it is still tacky about 3/4cured// you geat a fantastic bond on the topcoat
#7 | |
![]() Join Date: Jul 2012
cdowns if you think thats a bomb, come to west Texas. Most of the tractor tires have propane in them....
Locdock has it down...i have used it on many vehicles, and ive worn it on my hands and face out to nice events because this **** does NOT come off....
this stuff is great, but its not a miracle in a can. i half ass wire brushed some stuff under my jeep, painted it with POR 15 and i can see rust rings creeping back just like they would on anything else. i sandblasted the trailer hitch on my suburban, painted it, it looks like brand new. the can says its not uv inhibited, so youre supposed to paint over it. ive done that too, with good results. ive got two gallons in my garage now. im using some of it on the underside of a 69 camaro....some of it will go on my 71 C10 when i get the chance. the stuff likes some tooth, if you know what i mean. its got to have some roughness to grip to, you cant paint it on something smooth...good luck! ps. lacquer thinner will 'mostly' work..youll still have some residue... |
I brushed mine with a foam brush and it left no brush marks whatsoever. It looks damn good. A quart did our entire SWB frame. We scraped it with a scraper, powerwashed it, scrapped some more, then sanded it, then brushed it on. If you need pics look at my signature link 689 Short Step
Jason TEAM C10 HOT ROD POWER TOUR
689 Short Step 68 Step Trucks Sold: 70 GMC, 72 K5 Members met: Andy4639 GCncsuHD CSGAS zicc1835 hotrod farm truck Mingrao Bhelton brenthiggins |
dont get it on your skin or you will have it for a long time
Fuzzy |
![]() Join Date: Oct 2012
![]() Join Date: Jul 2006
Do not spray without a respirator.
Do not get it on anything you don't want to paint or destroy (this includes concrete). Do not get it all over your hands if your wife expects a soft touch. Do not let the lid seal with product, it will bond shut.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
![]() Join Date: Mar 2011
Do NOT spray without a good respirator.
This stuff is cured by moisture-----this is as dangerous or More dangerous than the old Imron paint was. It sprays well if you use a large enough tip,(and it brushes/rolls well) but like everyone has pointed out. Dont get it On you and be very diligent when spraying.
1997 shortie stepside 1968 short stepside 1966 mustang 1966 chevelle ss Dont always go the cheapest route--You can save yourself into the poorhouse! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=489030 |
#15 |
from what I understand a "can" of propane will air up alot more tires than the same size can of air. I guess the same size can will simply fill more tires. I dont know that its smart but I know that its pretty common, or at least it used to be when propane was so cheap..
#16 |
You can remove Por 15 from your skin easily if you use lacquer thinner right away, but thats not good to get on yourself either... better to use gloves. Everythign you want to know about POR can be found here.
http://www.por15.com/Data%20Sheets/POR15ApplicationInfo.pdf
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
#17 |
Por15 will not adhere to a smooth surface. At least not for long!
#18 |
Brakleen will clean it off your skin, and anything else, for about an hour, after that and you'll have it for awhile.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#19 |
i used it
brushed it on with no problems-2 coats did it outside -didn't use gloves but i would reccommend them like everyone else says
1969 stepside-305/4spd/12 bolt posi http://67-72chevytrucks.com/vboard/s...d.php?t=477157 1968 pontiac lemans convertible-350/pwrglde/10 bolt 1934 oldsmobile sedan-350/350/12 bolt posi 1930 model a pickup-350/350/jag ind 1928 model a roadster-283/350/9" |
#20 |
Here's something written by a friend of mine after he got done stripping, then painting the whole bottom of his car with POR-15. It's great stuff, but it is a gigantic pain in the ass at times.
You'll see my comment at the top of the comments section. http://aaroncake.net/misc/showthought.asp?thought=49 |
#21 |
What kind of brush should I use
#22 |
You can also use q-tips for ears to clean the can rim so lid doesn't stick, it's easy to clean perfect using this method or any paint can.
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride |
#23 |
argon works well for an inert gas to put into the can after use, apparantly it helps to eliminate any oxygen in the can (oxygen makes paints cure faster). also, I like to take a plastic trash bag and stretch over the top before putting the cap on, that way I have atleast a chance of taking it off if there is any product in the groove.
#24 |
Moderator
![]() Join Date: May 2007
I always use the small cans, no need to worry about resealing, just use it all at once and chuck the can. Always use a respirator, regardless of spraying or brushing it.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#25 |
who has had por 15 on their chasis the longest ? im still trying to determine what product i am going to go with, life expectancy info has proven hard to find on any of por 15 like products
