Old 12-18-2012, 09:26 PM   #1
sevensixoh
sevensixoh's Avatar
powerglide problems...help
hey all ... so im having trouble with my 2 speed powerglide ,
when I engage it in drive , the truck revs high and slowly crawls to the next gear and finally kicks in after about ten seconds. So I obviously cant drive it around town . But when I put it in reverse , it works great!!
please help , DIY fixing or other options .... anyone know how much a rebuild on a powerglide runs $$$ ... oh and its behind a 283 automatic..
thanks in advance !!
sevensixoh is offline   Reply With Quote
Old 12-18-2012, 11:51 PM   #2
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: powerglide problems...help
move and a bump.
Alan's Classic is offline   Reply With Quote
Old 12-19-2012, 09:27 PM   #3
crazy longhorn
Fabricate till you "puke"
Have you had the pan off the trans? I would suggest a screen & fluid swap, If you have not done that? I have seen that 'crutch' an old glide for a few more miles, & it will only hit you about 25-30 bones crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-19-2012, 09:38 PM   #4
sevensixoh
sevensixoh's Avatar
Sounds like a good start ! Kind of a newbie , so drain the pan and remove it , where is the screen located ?
Old 12-19-2012, 10:08 PM   #5
crazy longhorn
You will find it bolted to the valve body(with a couple bolts), after you remove the pan. A couple things to look for...lots of silver (as in the fluid in the pan looks lkie siver paint), or lots of black. Black is beautiful....but not on our food, or in the trans pan I have seen those old trans "varnish the fluid"...you might get lucky, or not....IMHO, worth a try on that glide?
Old 12-19-2012, 10:13 PM   #6
sevensixoh
sevensixoh's Avatar
Sweet , thnx ... I'll probably do it this weekend .
