Old 12-20-2012, 05:45 AM   #1
WOLFMANmike
WOLFMANmike's Avatar
question about my 72 burb
i have a 72 burban 3/4 ton i was wondering in anyone knows what the most common gear ratio is in the burbs back then ? i know originally it is a small block burb and its a 14 bolt floating axle rear end .. dont know if this info help you help me or not ? but im looking for a way to know what it has now and what i can change it to to get better MPG out of it lol i know mpg thats funny with such a heavy beast but im sure i can pull some out of it somewhere
ty in advance for any help you offer me
WOLFMANmike is offline   Reply With Quote
Old 12-20-2012, 09:53 AM   #2
Street Smart
Street Smart's Avatar
Re: question about my 72 burb
Welcome to the board!
I`m not a 3/4ton guy, but every C10 I`ve had came with 3.73 to 1 ratio. I`m sure someone with better info will chime in.
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile*
1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig.
http://67-72chevytrucks.com/gallery/...=74049&cat=500
Street Smart is offline   Reply With Quote
Old 12-20-2012, 09:58 PM   #3
bigpapinkc
bigpapinkc's Avatar
my burb came with a 4:56 but it also came with a4:10 eaton
1972 Chevy Burb. C20 bagged up
bigpapinkc is offline   Reply With Quote
Old 12-20-2012, 10:04 PM   #4
vectorit
What?
vectorit's Avatar
Hard to say, since your rig did not originally come with a 14 bolt.
Take a picture of the axle differential cover for us, just to make sure there is no misunderstanding.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 12-21-2012, 02:49 AM   #5
WOLFMANmike
lol that's a good idea ... i don't know why i did not think of that before i will post a pic tomorrow to dark now ty for all your help
Old 12-21-2012, 07:34 PM   #6
gearboxx70
Depends on the engine it rolled off the line with too. Mine is a C20 with a 292. I think it originally had 4.11 or 4.56 gears. The engine would scream at 50 MPH with the stock gears. Now I have a 12 bolt from a '78 pick up with gears in the low 3's (don't remember the exact ratio), and can do 70 when I need to. I just don't have enough power to get out of my own way now.
gearboxx70 is offline   Reply With Quote
Old 12-23-2012, 01:01 PM   #7
AzDon
AzDon's Avatar
Why guess about the ratio? It's easy enough to figure out...
Draw a line with a large felt pen on the pinion yoke and housing where you can see it crouching next to the truck. On the same side of the truck, put a mark on the tire at the very bottom. Have somebody drive the truck (forward or back) for one complete rotation of the tire and count the number of turns of the pinion yoke....
You will probably get either 3 or 4 full turns and a partial turn which will get you close enough to guess which ratio you have....
If there isnt a good sight line under the truck you can instead put a large zip-tie around the driveshaft and point the end at the ground when tightening it and count the number of turns that way...
Both rear tires need to be on the ground rolling in a straight line to eliminate the spider gears from fouling the calculation...
My 68 Burb figured at about 3:1 (likely 3.07:1) which I'm told is not uncommon in a c-10 Burb
AzDon is offline   Reply With Quote
Old 12-23-2012, 03:07 PM   #8
POS1
I think mine is a 3.73. It's a great ratio for getting moving while still highway cruising without high rpms.
- Brian
FleetFilter.com
1991 Chevrolet V1500 Suburban 4x4
1986 Jeep CJ7
1969 Porsche 911S Targa
POS1 is offline   Reply With Quote
Old 12-23-2012, 05:21 PM   #9
Yerboogieman
Yerboogieman's Avatar
I was told I have a 4.11 with Detroit lockers. That, paired with the TH350 equals not the best fuel mileage. I chirp the tires around corners all the time on accident.
-Taylor
1971 Chevy Suburban 4x4 Build Thread
Yerboogieman is offline   Reply With Quote
Old 05-28-2013, 11:43 PM   #10
68 TT
Still plays with trucks
68 TT's Avatar
If you do have the 4.11 gears and a locker in the Eaton HO52/HO72 rear end that is about as tall as you are going to find. Most were 4.57 or numerically higher. I understood there were 3.73's available but I have never seen any for sale ever.
The gears and parts for them are quite hard to come by and relatively expensive. You can sell your 4.11 gears and locker for more than what a whole 14-bolt would cost you to pick up and rebuild.
A 73-98 14-bolt is easy to come by and can be had with 3.73 gears quite often and have even taller gears available for them. Unless you have leaf spring rear suspension you will need to add trailing arm perches to it and run an aftermarket track bar / panhard bar.
The locker in your Eaton will fit into the 14-bolt carrier if you want to upgrade a non-posi 14-bolt.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 05-26-2013, 11:45 PM   #11
jeremiah king
jeremiah king's Avatar
keep an eye out for a swing dana 60.
Specializing in OEM 67-72 Chevy & GMC parts since 2001
1969 GMC Longhorn 396
1969 Chevy 3/4 ton LWB 396
1983 Toyota pickup 22R
2012 Toyota Scion Xb
jeremiah king is offline   Reply With Quote
Old 05-27-2013, 08:42 AM   #12
Bigdav160
Bigdav160's Avatar
Delete post
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
