12-26-2012, 09:18 AM | #1 |
2wd 1/2 ton control arms....is there an HD version?
My 1976 is a heavy half and has the 56" rear leafs, bigger brakes etc. I swear I read on here that either the upper or lower has an HD option with bigger shaft but I cant remember for sure. If there is a difference how can I tell what I have?
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
12-26-2012, 09:29 AM | #2 |
67-72 parts collector,…
Re: 2wd 1/2 ton control arms....is there an HD version?
Never heard of a HD control arm.
12-26-2012, 11:17 AM | #3 |
me either, but I swear I read Ken post that. I do know when searching for bushings it specifys 1-1/2" shaft for LCA and why would it specify that if there wasnt something different. I just want to make sure before I buy new parts.
12-26-2012, 12:02 PM | #4 |
Happy to be here
Ken? Which one..
The bushings, shafts, B/Js are different on the larger trucks. As far as I know the control arms are the same, even on the C30.
12-26-2012, 12:19 PM | #5 |
yes you lol....probably been a year ago, maybe you were recommending someone to upgrade to the bigger brakes while they were adding spindles I dunno, swore it was larger bushings/shaft size......oh well....its heck to get old
12-26-2012, 01:06 PM | #6 |
Could mean 13" diameter rotors or the HD 1-1/4" wide rotors vs. the 1" light duty rotors.
12-26-2012, 12:20 PM | #7 |
yes there is such a thing as a 1/2 ton hd truck that chevy made in the 73-80 years
don't know about the shaft though the innner and outers are bigger. i will let you know this week as i'm rebuilding the truck suspension. i take pics too
olyhotrodz |
12-26-2012, 12:21 PM | #8 |
if you had an hd truck the glove box should tell you it it is that model should say hd option.
olyhotrodz |
12-26-2012, 03:05 PM | #9 |
Ok I have the 1.25 rotors
12-26-2012, 04:07 PM | #10 |
The arms are the same except 1/2 ton use rubber bushings where 3/4 to 1 tons use greasable style bushings same as 63 to 72 1/2 tons. Ball joints are bigger too.
12-26-2012, 05:24 PM | #11 |
Watch out for your cornhole !
And some of the real heavy duty 1 tons used a different control arm shaft. On my R30, the lower shaft bolts to the crossmember, and not with u-bolts either. The shaft itself has jugs on it that bolt straight to the bottom of the crossmember with nary a Ubolt in sight.
02-09-2013, 09:07 PM | #12 | |
1954 3100 Nova Subframe, Pontiac Posi, roller for now1967 C-10 SWB 350/350/Posi. Soon to be Crew Cab! 1978 Crew Cab Dually roller 1982 C-30 Rollback, 454, 4 speed 2004 K1500 Suburban Z71 5.3 Kid Mover Last edited by 6 Door King; 02-09-2013 at 09:09 PM. Reason: remove extra verbage |
12-26-2012, 05:44 PM | #13 |
Okay thanks guys
02-09-2013, 09:19 PM | #14 |
I haven't personally confirmed this with my own hands, but its commonly reported here on the board that larger trucks used bigger ball joints, not just the stud, but the body being bigger with a correspondingly bigger hole in the control arm.
Posted via Mobile Device |
