Old 12-26-2012, 03:51 PM   #1
1955 mancave
1955 mancave's Avatar
dana 70
can anyone tell me if i can use the ring and pinion housing out of a Dana 70 SRW and install it in a Dana 70 DRW ? the reason i ask is that i have a lead on a DRW and SRW but the gears i want are in the SRW, so i want to know if i can just swap center sections or ??
please advise
Thanks.
Henry.
1964 1 Ton flatbed service truck (sold)
1964 C-10 panel (project complete frame up build)
1957 210 post pearl orange
1955 mancave is offline   Reply With Quote
Old 12-27-2012, 12:32 AM   #2
Captainfab
60-66 Nut
Re: dana 70
As long as both are the standard Dana 70, yes they will interchange. However the gear pattern and backlash will need to be checked when installed in the new housing.
Old 12-27-2012, 08:06 AM   #3
1955 mancave
Re: dana 70
thanks, now even if i take the third member out and swap it with the gears installed would i still have to check back lash , i would think not but then i'm not the rear end guy,
thanks John.
Old 12-27-2012, 08:26 AM   #4
tincan1966
tincan1966's Avatar
Re: dana 70
Yes, anytime you disassemble a differential, you need to reset the backlash on the gears.
tincan1966 is offline   Reply With Quote
Old 12-28-2012, 02:08 AM   #5
Captainfab
60-66 Nut
Re: dana 70
Yes, just as tincan1966 said. Anytime you remove the carrier and ring gear and the pinion and install them in a different housing, everything needs checked again. Once in a while you get lucky and they don't need adjustments, but they do need to be checked.
