Old 12-27-2012, 11:14 PM   #1
ryanroo
ryanroo's Avatar
A/C cab ?
so i did some searching, but i didn't find an answer. outside of the obvious dash vents, is there a significant difference in the cab for an a/c truck vs the non a/c i.e. the firewall?
i was planning on using an aftermarket system, but i am a little sketchy about not having fresh air, and i want a good heater. it gets pretty cold here and id rather not worry about having foggy windows.
my truck is a non a/c truck factory, but i was going to buy the inside and out dash boxes and the controls etc. is this going to be a headache?
thanks
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 12-27-2012, 11:25 PM   #2
Graham57a
Graham57a's Avatar
Re: A/C cab ?
As for the firewall I'm pretty sure they are identical with the exception of a few extra holes. Now running aftermarket AC systems, they usually use different designs on the engine side of the firewall. Most guys who do custom truck and want vintage air or something similar start out with a non ac cab so they can make it how they want it. I'm pretty sure when you get a kit from vintage air or a company like it they design their kits to fit non ac trucks as well as stock ac trucks. Hope this helps
Graham57a is offline   Reply With Quote
Old 12-28-2012, 12:19 AM   #3
WIDESIDE72
WIDESIDE72's Avatar
Re: A/C cab ?
The firewall holes are different. Someone on the parts board was looking for an AC firewall piece behind the plenum to do a swap such as the one you netion, but you don't need the wholepiece, just make a patch.
http://67-72chevytrucks.com/vboard/s...d.php?t=407652
WIDESIDE72 is offline   Reply With Quote
Old 12-28-2012, 01:47 AM   #4
Andy4639
Old member
Andy4639's Avatar
Talking Re: A/C cab ?
Graham57a,
See if this works. You will need the AC when we head out in June for the Power Tour. Texas will be a little warmer than here I would think.[ The humidity should help a lot though.
Thanks to member
john for the picture. Most aftermarket AC/heater kits have no engine side boxes just the hoses that come through the fire wall.
Here is a picture of one.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-28-2012, 02:22 AM   #5
SS Tim
SS Tim's Avatar
Re: A/C cab ?
The service replacement cab was not offered in an A/C version and required modifications as listed to give an idea.
SS Tim is offline   Reply With Quote
Old 12-28-2012, 02:55 AM   #6
WIDESIDE72
WIDESIDE72's Avatar
Re: A/C cab ?
[QUOTE=Andy4639;5781307]...You will need the AC when we head out in June for the Power Tour. Texas will be a little warmer than here I would think...
GUARANTEED!
Old 12-28-2012, 03:27 AM   #7
Andy4639
Old member
Andy4639's Avatar
[quote=WIDESIDE72;5781372]
GUARANTEED!
I'll have mine tuned up for sure with extra freon with me!
Old 12-30-2012, 04:02 PM   #8
Graham57a
Graham57a's Avatar
Re: A/C cab ?
[QUOTE=Andy4639;5781307][B][COLOR="Red"]Graham57a,
I wish I was going to have AC, but if I'm taking Jane I will barely have the funds to get the paint and wheels. I'll just roll my window down and drive fast!!!
Old 12-28-2012, 09:05 AM   #9
ryanroo
ryanroo's Avatar
Re: A/C cab ?
Thanks Guys!
that was what i was looking for! sometimes it seems like whenever i do a search i get a lot of threads that have nothing pertinent to my search in them.
ryan
72 K20 12v build
Old 12-28-2012, 09:42 AM   #10
mrein3
mrein3's Avatar
Re: A/C cab ?
Since it appears that Frontier fixed my intenet connection, let me post some pictures to help you see what you need to do if you want to convert a cab from non-A/C to A/C.
First of all, the picture Andy4639 posted isn't perfect but it worked for me when I did this. The red and yellow holes actually line up in real life. The person who made that picture didn't get it 100% perfect but it gives you an idea of what you are in for.
First note that in a non-A/C cab, there is one of the two heater core pipe holes cut. There is a dimple for the other one. (This is my truck by the way, the AC is up and running after the mod.) I used a Greenly (sp?) hole punch to make a nice, round hole.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 12-28-2012, 09:47 AM   #11
mrein3
mrein3's Avatar
Re: A/C cab ?
Then using the A/C heater box and your firewall with two holes in it, make a template. Use the two holes for the heater core to line things up.
'72 Malibu hard top
Center City, MN
Old 12-28-2012, 09:49 AM   #12
mrein3
mrein3's Avatar
Re: A/C cab ?
I marked up that template Andy4639 posted...
'72 Malibu hard top
Center City, MN
Old 12-28-2012, 09:50 AM   #13
mrein3
mrein3's Avatar
Re: A/C cab ?
Happiness is a wet spot (make sure your drain on your new A/C box isn't plugged).
'72 Malibu hard top
Center City, MN
Old 12-28-2012, 10:18 PM   #14
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: A/C cab ?
Great info Mrein3!
Ryan
1969 Chevy milk truck
Old 12-28-2012, 10:23 PM   #15
1972RedNeck
1972RedNeck's Avatar
Re: A/C cab ?
thanks
Ryan
How are you going to use the stock box with your hacked firewall?
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 12-29-2012, 11:26 AM   #16
ryanroo
ryanroo's Avatar
Re: A/C cab ?
i didn't hack the heater box mounting area. i went just to the edge of the flat that the heater box mounts on.
if it doesn't fit, which i think it will by visually scoping it, i will do what i do best! cut more sheet metal! i can always use an aftermarket system if i need to, but that will be a fallback now. and since i know you can fit 2 turbos and factory a/c i dont have to worry about that!
Ryan
72 K20 12v build
Old 12-28-2012, 10:26 PM   #17
BigRed76
BigRed76's Avatar
Re: A/C cab ?
Does anyone know how the aftermarket A/C & Heater kits utilize the blower motor under the dash so there is nothing mounted on the firewall?
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 12-28-2012, 10:34 PM   #18
Dieselwrencher
Re: A/C cab ?
The entire heater housing is one unit that fits behind the fire wall and the blower motor hangs down towards the floor on the 67-72 kit I believe. They don't use the cab to seperate their case halves in other words.
Ryan
Old 12-28-2012, 11:06 PM   #19
SS Tim
SS Tim's Avatar
Re: A/C cab ?
Since this is probably relevant I wanted to bring up the fact that there were Dealer Accessory Four Season A/C kits listed in addition to under-dash and roof mounted kits. With a ten hour flat rate install it seems only a little more difficult than an under-dash listed at nine hours. Has anyone seen one of these kits or installations? The installation instructions? Was there a block-off plate that covered the stock heater opening as part of the kit?
Old 12-29-2012, 11:02 PM   #20
BigRed76
BigRed76's Avatar
Re: A/C cab ?
I'm thinking about taking a factory A/C underdash air box and adding the blower motor to it so i can have all of the vents with heat, and nothing under the hood on the firewall.
Zach
Old 12-29-2012, 10:43 PM   #21
Andy4639
Old member
Andy4639's Avatar
Wink Re: A/C cab ?
I did my non AC truck without the help of all these pictures. I took the whole heater unit out and stuck the AC outside box up to the fire wall and marked it out. It's not perfect but it works fine.
Old 12-29-2012, 11:10 PM   #22
AusTx68
AusTx68's Avatar
Re: A/C cab ?
I added a Vintage Air system to my non AC cab. My firewall is smooth so I couldn't go with the out-of-the-box setup.
Personally I would avoid a stock AC setup. That technology is 40+ years old. The new aftermarket systems are highly efficient and do a great job.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 12-29-2012, 11:47 PM   #23
ryanroo
ryanroo's Avatar
Re: A/C cab ?
ive read as much as i could as far as reviews go, and while i have no doubt the a/c is fine with the aftermarket systems, i've been reading that many are less than impressed with the heaters. where i am, it is common to see below 0 and normal to have 10-20 degree mornings in the winter. i want a great heater. also the lack of fresh air bothers me. if you are dealing with snow, the moisture you bring in on your boots will fog the windshield and not go away no matter what you do if you are not bringing in fresh air. if the a/c is less than the best, i will still be a happy camper. i am not sure what differences have been made in the technology of refrigerated air in cars, but i am willing to bet that it wont be so drastic that i am unhappy. plus, if i can find the darn paperwork, i am licensed to purchase R12. ive been in many 70s era vehicles that could frost over your man parts with r12.
72 K20 12v build
Old 12-30-2012, 02:28 PM   #24
Dieselwrencher
Re: A/C cab ?
[QUOTE=AusTx68;5784633]I added a Vintage Air system to my non AC cab. My firewall is smooth so I couldn't go with the out-of-the-box setup.
Personally I would avoid a stock AC setup. That technology is 40+ years old. The new aftermarket systems are highly efficient and do a great job. [QUOTE]
There's nothing wrong with a stock a/c system. They worked great back then and will again. Sealing up the cab is more of the issue. And many people do not properly charge a retro'd 134 system.
Ryan
Old 12-30-2012, 06:18 PM   #25
AusTx68
AusTx68's Avatar
Re: A/C cab ?
I think that depends on where you live. Here is Texas I have heard plenty complaints about the performance of a stock system. With that said, I'm sure someone from Texas will say there's works fine. It comes down to what gives you the best comfort for your weather conditions.
