What does this button do?
I got a 1970 c20 custom camper and was wondering what the little silver button beside the parking brake release does or should do. Anybody know?
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: What does this button do?
Doesn't sound stock.... might have to trace wires to see what it goes to.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
That is what mine does. It is not a button it is a turning switch, to the left is my main tank and to the right the aux.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
Pictures are always helpful.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
1969 Custom 30 wrecker
WHAT EVER YOU DO, DON'T PUSH IT!!!
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
nevermind
-CJ- 69 GMC stepside 350 370HP TH350 4:11's 8MPG and proud! Last edited by Survivalist45; 12-30-2012 at 10:02 PM. Reason: Actually thought about it |
20' Daredevil (Ret)
Glad you figured it out......... now tell us what it is!
please
![]() Join Date: Oct 2009
Never mind what? Anyhoo....
If it is next to the parking brake handle, I don't believe it's original. If it is just above where the driver's side a/c vent would be on the open space sheet metal, it is likely a factory fuel gauge switch (switches between main and aux tank fuel level to be displayed on the gauge). The fuel selector valve is normally on the driver's side floor, just inside the sill near the seat adjust lever. Yes, a pic would be most excellent. Shown are the gauge selector switch (pic 1) and fuel tank selector switch (pic 2) (note - the factory gauge selector was not a toggle, it was a rotary knob, just shown for location's sake...): If it's a factory setup, you should have an NL2 code on the SPID (and both of the below switches). Last edited by jocko; 12-30-2012 at 11:08 PM. |
I typed something without thinking, my brain automaticlly went to people I know never seeing my high beam switch before, and I typed that, so I had to delete it.
-CJ- 69 GMC stepside 350 370HP TH350 4:11's 8MPG and proud! |
More than likely it's just a switch some previous owner put there. That area seems to be the first place they drill holes for switches. I see it all the time in junkyard trucks.
In fact, I have a hole in one of my trucks I still have to weld shut! ![]()
![]() Join Date: Sep 2010
Location: Formerly MD and San Diego, now loving life in Arizona
Passenger Ejection Seat activiation?
Sorry....my old B52 Air Force days coming back to life.... ![]()
Alan 2012 Ram 3500 Dually Crew Cab 6.7 Cummins 2014 Palomino Columbus 340RK 5th wheel '69 Chevy C10 396BB |
I'll get a pic up soon.
Posted via Mobile Device |
#15 |
I followed the wire and it goes to the temp. gauge
#16 |
20' Daredevil (Ret)
Odd -- is there another wire from that button? If so, where does it go? I'm trying to think of a reason for a button to be wired to a temp gauge.... It's kinda like the PO was either using that gauge for something else entirely, or wired it to monitor two different functions (selectable with the button).
#17 |
#18 |
Junior Member
![]() Join Date: Mar 2015
I know, it's an old thread. But I have this button and I am wondering if anyone else has seen this as well. No clue what it does...
#19 | |
![]() Join Date: May 2012
Careful... don't push that button! ![]()
White K20 |
#20 |
Elmer Fudd: I think I'll push this wed one.
Daffy Duck: No! No! No! No! No! Not the wed one! Don't ever push the wed one! http://www.imdb.com/title/tt0046902/...item=qt0531443
#21 |
Junior Member
Despite the risks of time travel, ejection or maiming, I pushed the button. Once while parked, killed the engine. Once while driving. I held it down, pumped the accelerator and released hoping it would make an extremely loud noise and catapult me into 2017. Engine died and it was really tough to start after. I am not pushing that button anymore. Traced the wire but it gets lost behind the cowl. It is wrapped up with a couple others so I will sort it out when I have some more time. Thanks for the entertaining responses.
#22 |
![]() Join Date: Apr 2016
What is the button wired to? Let's see a picture.
#23 |
![]() Join Date: Mar 2000
My bet is it engages the flux capacitor.
Saskatoon, Saskatchewan Canada |
#24 |
^ ^ I'll second that doc ![]() ![]()
.................._____ __________//___{\____ /__---____//____/__---/ .....(O). ..................(O). BUILD THREAD K20 http://67-72chevytrucks.com/vboard/s...d.php?t=651601 pages 2-4 ![]() |
#25 |
![]() Join Date: Jul 2015
