12-31-2012, 03:25 PM | #1 |
timing question
so i just returned from a deployment, gettin the old square tuned up, its a 84 k10 with a 350, a few months before the deployment i rebuilt the carb on it (eldebrock) i just adjusted the plunger on it, had a little hesitation, i just put a new exhaust on her, wanting to advance the timing a little on it, when we rebuilt the carb we put it back to the stock setting, im just trying to get a little more out of this old dog, any tips besides the timing would be helpful too!!!
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
12-31-2012, 06:55 PM | #2 |
Re: timing question
seriously? no tips or recommendations?
01-01-2013, 03:47 AM | #3 |
Re: timing question
timing will only get a fue hp gain and 12.8 air fuel ratio will make most power
the only things i can think of changing is cam, compression ratio, and displacement a small carb will restrict power like my 383 when i put it on the dyno i had a 500cfm carb and it only made 318hp i havent had the chance to dyno it again seeing i just got back from a diployment in october and i just put the fast ez efi on and the fuel pump took a crap right out of the box so as soon as winter is over ill see what it will do
88 gmc v3500 bonus cab classy chassy conversion, 454, nv4500, np205, dana 60 front with spool, 14 bolt ff cac rear with locker. |
01-01-2013, 06:52 AM | #4 |
Re: timing question
stock motor?
anything done to motor? where is all your deployment money.. ? |
01-01-2013, 11:21 AM | #5 |
Re: timing question
im thinking of going to efi, just trying to maximize what i can out of this old engine til the spring when i put a new engine in it
and bk2life, im married so dont have a whole lot of deployment money left, tried paying some bills this deployment
01-01-2013, 11:38 AM | #6 |
Re: timing question
I find these websites very good when it comes to engine timing:
Ignition timing 101 and HEI Tuning Secrects also if its an old engine, check to see if the timing is steady at idle and when you slowly increase the rpms. if the needle constantly is jumping around, then your timing chain is stretched and gears are probably worn. this will cause the camshaft and distributor to be out of sync, actually never be in sync, thus resulting in performance-loss. change the timing chain to a "double roller" version. this double roller will have less friction and is easier to turn around, resulting in a couple op HP gained and engine revs easier. If you dont mind loosing a little HP in the high range you can gain a little torque in lower rpm's by advancing the timing chain 4 degrees. usually these double rollers will offer 4 advance or retard notches. hope this helps you
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
01-01-2013, 11:44 AM | #7 | |
Re: timing question
01-01-2013, 11:39 AM | #8 |
Parts and more parts
Re: timing question
I suggest playing with your timing and going towards the 12 degrees BTDC. I had my 350 up to 15 degrees in the past, but now I use a timing light with an advance dial on it and I set my timing to a "TOTAL" advance around 35 degrees. It is something that you have to play with and watch for detonation (piniging) in you engine after each adjustment.
You mentioned that you just rebuilt your edelbrock. I suggest gettnig a vacuum gauge to adjust the idle air screws on it to make it the most efficient that you can. To do an adjustment with a vacuum gauge, you need to connect the gauge to the intake manifold and get your baseline vacuum indication. First thng is to pick one idle air mixture screw and turn it inwards till you get a significant drop in idle and vacuum signal. Next turn the screw outward until the vacuum reaches the highest point it will return to on the gauge. Now do the other air mixture screw the same way. Once you have returned to a good vacuum signal, REPEAT the process to get the screws to a point where they are seeing the most vacuum. The final thing is turn the screws inward approximately an 1/8 of turn and you have set your carb idle air mixture using a vacuum gauge.
Frank |
01-01-2013, 11:46 AM | #9 | |
Re: timing question
