Registered Cruiser
Brake Booster Options
Hey fellas,
I'm running into a little issue with space between the OEM 11" brake Booster and my shift linkage for the 4l60e. I'm using the Lokar Cable linkage and the bracket that the cable end hooks too, doesn't allow the booster to bolt up. My questions is, can I use a smaller booster (something similar to this http://www.summitracing.com/parts/sum-760121-blk ), and still be ok? Engine is 03 5.3 with Zo6 cam, in a 77. Thanks, Justin
77' Chevy SB Dropmembered Front and Rear 5.3/4l60e combo |
Registered Cruiser
Re: Brake Booster Options
Well, did a little more research and found that I should go no smaller than an 8" diaphragm, should be ok with the dual 8" then. In case anyone needed that info
![]() Now just have to make sure it bolts up to my factory bracket ![]()
