01-03-2013, 11:58 PM | #1 |
exhaust system
i've got a 1985 chevy k10. It has a 350 in it and i was wondering what headers to use, along with what size pipe i should use and if true duels or a x pipe would be better for torque/hp gains. Thanks
01-04-2013, 12:11 AM | #2 |
Re: exhaust system
Welcome to the board.
For headers, I recommend Hedman Elite series. I can't speak for the 4x4 version, but the 2WD version had a superior fit and finish to the typical $100 headers. The cheap ones will leak, fry plug wires, and just don't fit the truck well. This is not a place you want to cheap out, or you will end up hating the headers and be begging for your manifolds back. For a 350 with a dual exhaust I recommend 2.25 inch pipe. As far as separate unconnected dual pipes, H pipe, and X pipe a lot of is it about sound and how much you want to spend. Personally, I would run unconnected dual pipes, but that is just me. I like the stereo sound you get from having the sides separate.
1977 GMC Sierra Grande |
01-04-2013, 12:26 AM | #3 | |
Re: exhaust system
I am putting Hedman headers and Dynamax 2.25 pipes on my 86 K10 hopefully this weekend if I get far enough along with the engine swap.
'86 Chevy K10 SWB Custom Deluxe 4x4 '94 Chevy Corvette '07 Ford Mustang '08 Lexus LS 460 |
01-04-2013, 12:34 AM | #4 |
Re: exhaust system
thanks as soon as i save the money ill see about investing into the headers and ill probably end up doing true duel pipes
01-04-2013, 03:02 AM | #5 |
Re: exhaust system
Pypes makes universal xpipes and completed truck systems. Check them out on summit
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
01-04-2013, 08:29 AM | #6 |
78K & 79C Jimmys
Re: exhaust system
I have duals on both trucks
79-305-2B-4X2 i did 2.25,custom,manifolds H pipe,to flowmasters 78-350-4X4-walker stock replacements ,manifolds to cherry bombs love em both
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
01-04-2013, 08:35 AM | #7 |
Re: exhaust system
is your 350 stock or modified?
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
01-04-2013, 10:59 PM | #8 |
Re: exhaust system
its basically stock
01-05-2013, 01:54 AM | #9 |
Re: exhaust system
I think the Pypes system is for 2WD only.
