Which choke thermostat?
Hi guys! First post! I've got a lot of great information from you guys on this site so I'm hoping you can help with this.
I got my '69 Chevy SWB about 6 weeks ago and the PO said it was a 327 (but I haven't yet found the casting numbers to be sure). It came with a Edelbrock that wasn't quite right so I replaced it with a rebuilt Quadrajet (7028282) from LMC. Question is what choke thermostat do I look for? TruckAndCarShop.com says they have one for a '69 327 but does this photo look to you guys like that's what I have? Any help would be great! |
Re: Which choke thermostat?
Welcome to the 67-72 Chevy Truck board from West Michigan!
Your manifold is from a newer Small block so the 67-72 truck chokes won't work. Here is a picture of a choke that is similar to the truck chokes. Also, note the difference between the manifold in my picture and the manifold in your picture. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
#3 | |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
You will probably need to switch to the older style manifold since you already have the older style carb
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Anybody have a guess as to what year that manifold would be from?
Active Member
![]() Join Date: Jul 2007
I have an intake like yours that came out of a '75 350. I'm using a carb with an automatic choke I already had.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
THANKS! That looks exactly like mine! I've searched quite a few times and could never find a photo that would show one like mine or if it did, it didn't say what it was from.
Can't see it the greatest, but we made a bracket that goes under one of the manifold bolts for mine:
71 K20 64 GMC mud truck |
I may try that with a thermostat that I have. I was concerned that it would not heat up fast enough. I guess having the choke come off too slow is only going to use a bit more fuel. Thanks for the photo!!
No problems warming mine up in the morning, works like a charm
My memory is starting to warm up and that pic of the aluminum manifold just kick started it. I believe edlbrock makes a block that bolts over that spot becauase new manifolds are made to accept the newer style heat tubes and they make an adaptor to go to old style
I'll see what I can find about that.
#15 |
Summit might be able to help you out
#16 |
I'll check on their website. Thanks!
#17 |
Florida Edition
![]() ![]() Join Date: Oct 2010
If you post up the manifold casting number we can tell you what it is, also the block casting number is on the top driver's side where the tranny bolts to the block and the build date is on the pass. side. Best way to see it is to hold your camera back at the firewall pointed down and snap some pics.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#18 | |
#19 |
Florida Edition
Also you could pull a valve cover and get the head casting number, a lot of things get swapped around in 40 years.
#20 |
