Old 01-04-2013, 02:06 PM   #1
Gigem
Gigem's Avatar
Hey, what is this thing on my steering column?
Look in the lower left part of this picture... What is that lever/"thing"?
It appears to be broken off. Truck has original floor-shifted 4 speed manual trans. Also... I can start the truck without the key... Just turn the ignition and it starts... Dont know if there is any relation or not...
Is this not the original column?
Just curious... I have a new column with shifter that I will use when my 700R4 goes in...
Gigem is offline   Reply With Quote
Old 01-04-2013, 02:09 PM   #2
69GMC910
MOTORHEAD!
69GMC910's Avatar
Re: Hey, what is this thing on my steering column?
I think its a ignition cylinder lock release.. Common on most manual transmission vehicles, but I dont know their purpose!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 01-04-2013, 02:09 PM   #3
MalibuSSwagon
Are you talking about the little lever next to the ignition switch?
That is the key lock for manual trans, you should have to push it down when turning off the truck. Unless its broken, that is.
MalibuSSwagon is offline   Reply With Quote
Old 01-04-2013, 02:15 PM   #4
84GMC15tepside
84GMC15tepside's Avatar
That's the ignition lock for taking the key out. Just press down the lever and turn the key in the off direction to take it out. Only for manual transmission trucks?
MY6 Stepside
84GMC15tepside is offline   Reply With Quote
Old 01-04-2013, 02:41 PM   #5
Gigem
Gigem's Avatar
OK, that makes sense all. Mine is busted, hence my ability to start truck without a key. Thanks!
1972 GMC Sierra Grande (current truck)
1980 Chevy Stepside (gone)
1987 Chevy Blazer (gone)
1972 Chevelle SS Convertible (gone)
1973 Chevy Corvette (gone)
1967 Chevy Camaro (STOLEN!)
Old 01-04-2013, 04:14 PM   #6
Wrecked1982
Wrecked1982's Avatar
on my 81 man.4 speed u have to push down that lever while turing back your key ortherwise it wont let the ign. key out
Wrecked1982 is offline   Reply With Quote
Old 01-04-2013, 04:49 PM   #7
69GMC910
MOTORHEAD!
69GMC910's Avatar
Cam somebody explain why this exists? It's obviously a safety reason??
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 01-04-2013, 05:05 PM   #8
whiskeydented
whiskeydented's Avatar
What year did they start having those? My 78 does not have that.
whiskeydented is offline   Reply With Quote
Old 01-04-2013, 06:37 PM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
In an Auto the key won't come out till it's "P" and the then it locks left to right
this keeps the key fwd ,not locking up the wheel
tumblers/cylinders wear out,common
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 01-04-2013, 07:36 PM   #10
raceman6135
Dino burner
raceman6135's Avatar
I don't know exactly when they began using them, but my brother's 1980 K20 GMC Sierra Grande has that style of lock column. It's a 350 small block engine and 4-speed manual transmission set up, stock from the factory.
raceman6135 is offline   Reply With Quote
Old 01-04-2013, 06:42 PM   #11
Wrecked1982
im pretty sure its a safety reason plain and simple... but it quickly get to be a reflex so ....instead of beeing a safety feature you look more weird shuting down other poeples car.
Old 01-04-2013, 08:00 PM   #12
bohmankid
bohmankid's Avatar
My 86 gmc has it, and so does my 83 s-10. both standard trans. My 84 and 85 chevys dont have it and they're both automatics. I was never sure what they were for either.. cool.
bohmankid is offline   Reply With Quote
Old 01-04-2013, 09:20 PM   #13
TwinTurbo
TwinTurbo's Avatar
All manual GM columns have a lever or a button that you have to press to get the key out. It does the same as the cable unlock in park on an automatic. It's a safety to keep you from turning the key back and having the steering lock up under driving.
TwinTurbo is offline   Reply With Quote
Old 01-04-2013, 11:51 PM   #14
whiskeydented
My 78 manual column doesn't.
Old 01-05-2013, 01:50 AM   #15
sethv
sethv's Avatar
My trucks' a '78 and it has it. The wheel doesn't actually lock but it's there
1981 K10 Scottsdale
305 ci | TH350 | NP208 |
60k miles
sethv is offline   Reply With Quote
Old 01-05-2013, 11:54 AM   #16
MalibuSSwagon
GM ignition switches are known to wear out. In high school I had a couple of friends with 80's FWD GM cars that could be started without the key.
Best fix is to rebuild the column with a new lock cylinder and replace other worn parts. Second best fix is to harvest a good functioning column with key from your local auto salvage.
Old 01-05-2013, 12:37 PM   #17
D13
D13's Avatar
My 81 3/4 with 3OTT does not have it, nore does my 77.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 01-05-2013, 08:08 PM   #18
TwinTurbo
TwinTurbo's Avatar
do you have to put it in reverse to get the key out? some manuals had that (not sure about trucks, talking about cars)
Old 01-06-2013, 09:57 AM   #19
whiskeydented
Nope, it can be in neutral, reverse or any gear doesn't matter. Key will come out.
Old 01-06-2013, 08:55 AM   #20
moneyeater
moneyeater's Avatar
I had a ´72 Cadillac Sedan deVille wich had a lever like that for the steering column to slide in and out! Only difference was that it sat on top not on the side of the column!
Volker
My little US vehicle parts business:
http://www.thegearheaddepot.com/
Come have a look!
´81 GMC C 10, Spanish Red
moneyeater is offline   Reply With Quote
