lmc truck lsx mount adapters and headers
looks like lmc has lsx swap adapters and headers now...
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=49 |
Re: lmc truck lsx mount adapters and headers
I saw that.... I guess that'll make it easy for some guys. But, with a little research someone could probably do it a little cheaper.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold ![]() 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold ![]() 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! ![]() 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold ![]() ![]() ![]() 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold) ![]() 2003 K2500HD 8.1/Allison1000/NP263 ![]() |
You can get those plates for $40 on ebay with the hardware.
I'm not sure on the headers but I'm sure they are just repackaging someone else's product. |
Fabricate till you "puke"
Those are headman headers....I picked up Hooker streetrod shorties , for $225 (carshop inc,Moline il). The plates, also from the moline shop....the long set , for setback(have to check, but I think 50 bucks). The eng lift plate also came from the same spot.....I like to work with my local speed shop, They always have my back
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... Last edited by crazy longhorn; 01-08-2013 at 01:47 AM. Reason: more info |
meowMEOWmeowMEOW
Cool....but I'm pretty sure those block huggers don't fit a ton of these applications.....and they DONT SELL THE FREAKING FLANGES SHOWN SEPERATE....
I already have some...but someone needs to mass produce the flanges in mild steel for a good price.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#6 | |
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
You want header flanges for an LS motor?
There's a local guy here that makes them and sells them on Ebay for dirt cheap IMO. |
meowMEOWmeowMEOW
Not the actual header side flanges (found those laser cut on ebay as well ), but the b-pipe flanges/cat pipe flanges. All I could find was the ls1 style, which arent' the same, and mostly in stainless (which I suck at welding). I ended up laser cutting some, but I'm surprised they werent more available.
B-pipe?
meowMEOWmeowMEOW
b-pipe is another name for a midpipe or downpipe or cat-pipe (occasionally test pipe if there was a cat delete). IMO its really only a downpipe on a turbo car, and some cars have a seperate cat-pipe, but with modern cars having multiple cats, the b-pipe is sometimes used to refer to the pipe in between the manifold and the cats, OR the flanged pipe between the manifold and something like a front merge pipe or y pipe.
Reading that I'm pretty sure i just made it more confusing. Its After the engine, and Before the Cats Hey longhorn, I didn't know that. I had to move my engine forward a tad to clear the firewall and make room for the 4l80e, and every set of huggers I could find dumped RIGHT into the perches.
I'm watching for updates on flanges !!
