Old 06-08-2003, 11:53 PM   #1
Low69CST
Dash restoration question
Is there a way to get the needles off the guages? I've heard about people painting them day glow orange. I tried to remove them, but they didn't seem to want to budge. Just thought I'd check before I broke something.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 06-08-2003, 11:56 PM   #2
68 Stepside
huh?
68 Stepside's Avatar
There's probably an easy way....I tried taking my speedo needle off once, it was white from all the sun....I broke the stud sticking out of the speedo guts clean off...it sucked....
Moral of the story: Don't try to force the needles off.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 06-08-2003, 11:59 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I just cut a slit in a sheet of thick paper and slide it under the needle then shoot it with spray paint.
Old 06-09-2003, 12:02 AM   #4
Piston
Piston's Avatar
yea what ^ he said. works great and you dont screw up a good set of gauges lol. I've broken a few and I've had a few come off. painting around them is much safer.
Piston is offline   Reply With Quote
Old 06-09-2003, 12:05 AM   #5
BUXMAN66
go bucks!
i used a toothpick to paint mine(still attached).
'68 swb 1/2t 350/350th
'86 lngbd 3/4 TON parts getter
'49 gmc 1/2 t 5 window 350/350th
'96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know?
BUXMAN66 is offline   Reply With Quote
Old 06-09-2003, 12:30 AM   #6
Alex Hayley
I found that the paper trick was a little bit difficult(I am a bit clumsy or so I am always told). I ended up using tin foil. Slip a piece of foil under the needle, bend it over the edge(s) of the gauge and it magically holds it position. Cover the rest of the gauge with foil. Worked great for me.
Alex Hayley is offline   Reply With Quote
Old 06-09-2003, 12:44 AM   #7
Low69CST
Yeah, my dad paints cars, we talked about slippin paper under it and spraying it. The tach is a little more trickier cuz it has that black ring around it. Plus some of the needles have small metal rivit things holding them on. I'll have to figure out some way to paint the needle and keep that part clean. Thanks for the advice though.
Old 06-09-2003, 03:21 AM   #8
bpmcgee
bpmcgee's Avatar
I just painted mine yesterday. I used testors model paint in a bottle, and a small chisel point paintbrush.
Brian
bpmcgee is offline   Reply With Quote
Old 06-09-2003, 05:53 AM   #9
Billy G
Billy G's Avatar
What about using a 'drenched' Q-tip? Ive used that on body paint touchups. Just sort of 'roll' the Q-tip
Good Luck!
My FAMOUS LAST WORDS...."Ima Gonna!!"
- 1970 GMC 1500 swb/step 250 I-6 3 spd - "The GEM"
- 1976 Chev Scotsdale swb/step 350/350 - "The JEWEL"
- 1982 Chev C-10 swb/step 250 I-6 3 spd -
- 2001 Chev Silverado LT -
Billy G is offline   Reply With Quote
Old 06-09-2003, 06:04 AM   #10
seacrow
seacrow's Avatar
I used legal pad paper, slit and placed around the needles. Then Odds n Ends hobby paint from Wal Mart. It works like a charm.
71 GMC Custom. 350, 4bbl., auto. Restored in memory of my grandfather.
2008 Ford F-250 Super Duty CC King Ranch, moonroof, heated captains chairs, 6.4 PowerStroke.
2007 Suzuki Hayabusa, all black
1985 Mustang GT T-top, 5 spd. 54K orig miles.
seacrow is offline   Reply With Quote
Old 06-09-2003, 07:48 AM   #11
BigBlack68
Negative Camber
BigBlack68's Avatar
i just pulled mine off,got lucky they came off real easy
BigBlack68 is offline   Reply With Quote
Old 06-09-2003, 10:34 AM   #12
jewels.
jewels.'s Avatar
i heard somewhere ( a long time ago ) that if you paint the needles on the dash, the extra weight added to the needles from the paint will throw off the readings
is this true?
jewels.
68 C10 Red Step 350 my first child & main focus
58 3200 Apache LWB Step the upcoming project
jewels. is offline   Reply With Quote
Old 06-09-2003, 10:38 AM   #13
Mixup
I've heard of using a fork to get under it and pry it off. Never tried it though.
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
Old 06-09-2003, 03:24 PM   #14
Longhorn Man
I have painted needles plenty of times and even multiple coats on a single guage...never had any weight issues...at least, not needle weight anyways.
Old 06-09-2003, 04:34 PM   #15
jewels.
jewels.'s Avatar
*snicker*
Old 06-09-2003, 09:32 PM   #16
blazerslave
blazerslave's Avatar
I used 4 pieces of thin cardboard which were larger than the gauge itself. I arrayed each piece of the cardboard so it covered the entire gauge except for the needle.
I sprayed a base coat of engine orange (duplicolor?) and when that got tacky, I brushed on flourecent orange which I bought from a local hobby store.
Looks like new!
blazerslave is offline   Reply With Quote
Old 06-09-2003, 10:47 PM   #17
Steven Sellers
Steven Sellers's Avatar
If you know anyone that works in a calibration shop get tham to get you a pointer puller. I havent tried yet on mine but if they do indeed come off, and Im going ot try, the correct tool is a must
2008 Buick Enclave(wifes new non wrecked)
1996 Jeep Cherokee
2002 2500HD 6.0L (traded)
1998 Jeep Grand Cherokee(wifes/wrecked)
1977 DJ5 postal jeep(mmm lots of fun)
1988 Toyota 2wd p/u(DD, blewup 199,000)
1991 Toyota 2ed p/u (sry just cant break these things)
1997 XR70 Honda
1991 Z50(FOR SALE)
1972 Z50 Honda
1970 SWB 350/knucklebuster "The adventure begins and I am confident that there will be no end".
Steven Sellers is offline   Reply With Quote
Old 06-10-2003, 02:35 AM   #18
casey
casey's Avatar
When you think about it why take them off, there already sitting on a nice pedistel slide the paper underneath, I think if you took two peices of paper both with a slit and side them in from either side you got it covered, that's my next project, any recommondations on a orange spray can, I've read on here before that some of you guys got a perfect match, with a spray can, just can't remember what kind it was.
casey is offline   Reply With Quote
