01-06-2013, 08:24 PM | #1 |
tow hook info
i got these tow hooks off a 72 k20 frame that was trashed. i wanna use them on my 71 k20 but the holes on the hooks dont line up with the two holes on my 71 frame. are these hooks factory? did they use diffrent hooks through the years?
1969 chevy c10 lwb stepside 250 6 3 ott 1971 chevy c10 lwb 250 6 with power steering 3 ott 1972 chevy k20 4x4 350/TH350 automatic 1978 chevy Malibu 4dr 305 2bbl (all original) 1979 chevy k10 Scottsdale 350/th350 full-time 4wd(daily driver) |
01-06-2013, 08:31 PM | #2 |
Re: tow hook info
Those were used in 1972 only. They sell for about $100 more that the 69-72 style hooks. The bolt holes on the two styles are the same so you will have to drill either way.
The "extreme bend" tow hooks started sometime in 1972. The 69-72 style was used a little ways in the 72 production run. I doubt anyone would notice if you use that style, and if they did it wouldn't matter. Edit: check out this thread. It has 69-72 style hooks pictured, but also mentions the 72 style mounts differently than the 69-72 style. http://67-72chevytrucks.com/vboard/s...d.php?t=305926
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. Last edited by 71swb4x4; 01-06-2013 at 08:37 PM. |
01-06-2013, 08:37 PM | #3 |
Carpe manana
Re: tow hook info
Those are 1972 specific tow hooks the "extreme bend" hooks - a one year only deal. These bend in the same direction (i.e, one sided). The correct hooks for a 71 are the 69-72 type: these bend in opposing directions (i.e., there is a RH and a LH hook). In at least 72 the 4wd frames were all drilled for hooks by GM whether or not the truck was so equipped. I have a spare set of 69-72 hooks to trade!
01-06-2013, 09:18 PM | #4 |
Re: tow hook info
are they worth so much more just because they are 72 only? i think ones going away from each other would look better.
01-06-2013, 09:59 PM | #5 |
Carpe manana
Re: tow hook info
I believe the 72's command more $$ because they are a one year off option and supply is limited. Some guys do prefer the more balanced look of the 69-72 hooks: I have a set of 69-72 on my K10 now for that reason but will put the 72 only style on my K20 resto.
Here are some comparison pics I saved that were posted by a board member in a thread I wasn't able to find on a quick search so can't give credit where do.
01-07-2013, 09:29 AM | #6 |
Re: tow hook info
I will trade you the correct style for your truck(69-71) if you want to ..PM me if you like....
WTB 1972 CHEVY 3/4 4X4 1971 chevy c30 4x4 NAPCO (project) 1972 chevy 3/4 4x4 350/350 4spd, tach, tow hooks,radio delete,heat delete,hubcaps,lockers 1972 chevy 3/4 4x4 383/350 dads original farm truck tilt,tach,tow hooks,hubcaps,radio delete,heat delete 2006 chevy LBZ crew cab duramax,4 inch,beadlocks 2015 chevy tahoe Z71 my fifth one,love em 2016 chevy 2500HD Z71 LTZ duramax midnite 2018 chevy suburban Z71 midnite |
01-09-2013, 07:30 PM | #7 |
Re: tow hook info
This is what I have ...
01-09-2013, 11:01 PM | #8 |
Re: tow hook info
71 frames were not drilled unless hooks were ordered, I added hooks to my 71 and had to drill the holes
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
02-03-2013, 12:30 AM | #9 |
Re: tow hook info
Would u be willing to part with a set? Need a set for 1970. Thanks.
1967 SWB (small window) original 1970 4x4 STEP 1970 CST SWB FLEET 1972 SWB FLEET ORIGINAL |
02-13-2013, 11:18 PM | #10 |
Re: tow hook info
Hello. found this thread to be quite interesting. I have a pair of 67-68 tow hooks (based on Deadhead NM's tow hook layout). I have yet to install them on my '72 K 1/2 ton Suburban. Opon initial inspection it does'nt look like they want to fit my frame. My frame came with the tow hook holes predrilled. The tow hook holes do line up with my frame but it seems like the bumper is slightly in the way. Should these tow hooks fit my truck ? If not would someone want to do a trade for the other style. Mine have the extreme curl where the two holes are located. It seems like the other ones that have a straighter neck (where mounting holes are) would fit.
Any thoughts. Thanks, J |
01-09-2013, 11:07 PM | #11 |
Re: tow hook info
Does anyone have good pix of these installed?
Posted via Mobile Device |
01-09-2013, 11:16 PM | #12 |
Carpe manana
Re: tow hook info
Not my pics...
01-09-2013, 11:21 PM | #13 |
Re: tow hook info
Cool thanks, Have to see if I can find a set of those.
01-09-2013, 11:25 PM | #14 |
Carpe manana
Re: tow hook info
You bet. Maybe Jeremy will part with one of his sets?
01-10-2013, 05:06 AM | #15 |
Re: tow hook info
Wow really glad I found this. I happen to have a set of 72 only hooks I snatched off a beat up Jimmy and was saving them for a worthy truck. I have a 72 K10 but I'm not sure the holes lined up good for them.
Erik 1969 Chevy K20 6.0L/4L80E/NP205 1971 Chevy C30 Cheyenne Longhorn 454/TH400 1979 Chevy K30 dually currently in pieces |
