Re: first post and got cuple questionsgot questions
Welcome!
IF I'm reading this, I'm thinking the 83 Silverado is a SWB truck and the 63 is a LWB? That would be a tough frame swap. You could possible find a SWB 63 bed and make the swap work but that's a still BIG project. Does the 63 have a transmission? The 305 would be a pretty easy fit in the 63 if the trans is there. Do a search, plenty have put V8's in these old trucks. Lots of info here... |
60-66 Nut
Welcome to the forum
![]() It will be much easier to just put the 4x4 running gear under your original '63 frame. There is a thread on here titled "SixfoSuburban" by Jonzcustomshop, where he is doing just that. Keeping it 2wd is also easily upgraded to PS and power disc brakes. It's just a matter of whether you want a 2wd or a 4x4.
#4 | |
id start off on puttin a motor in it and getting the truck driving before dreaming about 4x4, lifts, big tires, all that jazz you probbaly dont have money for. not being a jerk, being realistic, get a motor/trans and get the truck running and driving. a 2wd cleaned up painted vintage truck is still a show stopped and a girl getter..
This is a 63' long bed that started out as a 2x4 and was converted to a 4x4 using a 73' Chevy as a running gear donor. I did not do the work but know the guys who did and they say almost everything bolted right up.
Tags |
63 c10, 63 c10 4x4 |
