01-09-2013, 11:37 AM | #1 |
Diesel to gas
I have an 83 stepside 4wd that used to have a diesel engine in it. I would like to put a small block 350 back in. Do I need to change the dash and engine bay wiring harnesses to run the gas engine and gauges from a gas engine donor truck?
Thanks, Ray |
01-09-2013, 12:14 PM | #2 | |
Re: Diesel to gas
Is your truck currently 24V? Why would you need to change the gas gauge?
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF |
01-09-2013, 12:21 PM | #3 |
Re: Diesel to gas
My truck is 12v and the current gauge cluster has diesel on it. I will need to power up the HEI instead of the glow plugs, injectors, etc.
01-09-2013, 12:44 PM | #4 |
Re: Diesel to gas
Its my understanding that the power wire for the injector pump is what you will use to power the HEI as for the gauges, just use the sensors for the 350,fuel gauge will work also, just dont put diesel in it anymore. Check out The Diesel Place for more info on the glow plug relay wiring.
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
01-09-2013, 04:14 PM | #5 |
Just here to tinker
Re: Diesel to gas
You should be able to unplug the glow plug harness from the main wiring harness and that'll clean up some of the wiring. Make sure to remove the glow plug controller, otherwise you may still get WAIT and GLOW lights coming on.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
01-09-2013, 07:36 PM | #6 |
Moderator
Re: Diesel to gas
All of the 73-91 Squarebody the wiring diagrams are in my sig.
The fuel cutoff wire will power the HEI. The gauges are the same with the exception of a possible "Diesel Fuel Only" warning. You'll have a couple diesel warning lights in the dash that won't do anything but they aren't hurting anything either. If you have an automatic... You'll need a gasoline tranny. Sell the diesel tranny with the diesel torque convertor if you have them. Manual? get a flywheel and clutch and bolt that baby on. Stock 82 & 83 diesel tank senders have a water siphon outlet with a line attached to a valve in the forward rear spring hanger. You'll need to properly deal with that.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
01-09-2013, 10:57 PM | #7 |
Re: Diesel to gas
I thought the trans would only require a change in the Governor and Converter?
01-10-2013, 12:19 AM | #8 |
Moderator
Re: Diesel to gas
I thought there were tuning differences in the valve body springs etc.
01-10-2013, 12:28 AM | #9 | |
Re: Diesel to gas
Frank Posted via Mobile Device
Born and proudly residing in a Red State ! |
01-10-2013, 12:38 AM | #10 |
Just here to tinker
Re: Diesel to gas
Only the olds diesels have a BOP bellhousing. 1981 was the last year for the olds. 6.2 and 6.5 share the same chevy bellhousing.
01-10-2013, 12:42 AM | #11 | |
Re: Diesel to gas
Thanks, Frank Posted via Mobile Device
01-10-2013, 01:16 AM | #12 | |
Re: Diesel to gas
01-10-2013, 01:55 AM | #13 |
Re: Diesel to gas
Thanks for all of the input. It looks like I will be able to use the original harness, but I will change the cluster since I have one in stock. BTW its a 4 speed sm465 so no worries on the trans.
