Old 01-09-2013, 03:50 PM   #1
Longhorn 70
Longhorn 70's Avatar
Is there a color code or name for Steering Column??
Is there any special name or color code for a steering column?? Mine is a brownish color and needs help to get back to looking good.
Thanks in advance for any help.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 01-10-2013, 04:01 PM   #2
Longhorn 70
Re: Is there a color code or name for Steering Column??
No one??
Old 01-10-2013, 06:30 PM   #3
jocko
jocko's Avatar
if brown-ish, it's likely "sandalwood" (color). Is it kinda light brown? Maybe the name will help you search for some - I'm not sure where to find it, but can perhaps run with sandalwood on google and see what pops up. If it's not ligth brown, then it could be part of a "saddle" interior. What color are your seats and dash pad? Pic would help - someone on here can spout the definitive answer from a single pic.
Old 01-10-2013, 09:45 PM   #4
Longhorn 70
Jocko,
I don't have the interior done now....Lots of parts removed to paint and restore.
The door panels, seat and armrests were Off White or Parchment. I have seen it called different things. Parchment is the color of the new stuff for the interior. The carpet I found is Light Sandlewood.
I am waiting on the seat now.
Old 01-10-2013, 10:34 PM   #5
hugger6933
Go to your local PPG paint supplier[mine is an Orielly's auto parts] and ask them to use their profit machine on it. You will need to take your column with you and they will take a digital image of the part and the camera will download that pic into their computer and it will transfer that pic into a mixing formula or color code in witch they can mix the paint from. Another option is go to your local John Deere store and pick up a can of Blitz Black. It is avaible in spray cans and it is the closest thing I have ever found to the factory tilt colors that GM used on their steering columns.
hugger6933 is offline   Reply With Quote
Old 01-10-2013, 10:49 PM   #6
Longhorn 70
Mine is a funky tanish brownish grayish color.
Old 01-10-2013, 10:54 PM   #7
jocko
jocko's Avatar
For a parchment interior, sandalwood should be the color of the non-tilt columns and steering wheels.
Old 01-10-2013, 10:59 PM   #8
Longhorn 70
Thanks. That looks like it should be. Sandalwood it is.
Now how about helping me to get 24 MPG.... j/k
Thanks again
Old 01-11-2013, 07:55 AM   #9
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Talking Re: Is there a color code or name for Steering Column??
Thanks again
No problem on that. Just drive down grade all the time.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 01-11-2013, 11:31 AM   #10
mgkgmc
mgkgmc's Avatar
I was thinking its the medium gold poly. Its really a tan color.
1970 GMC 1500 stepside
1972 GMC Jimmy Custom
2004 Chevy Colorado
1989 Swb Silverado
1972 Aj's Stormer
mgkgmc is offline   Reply With Quote
Old 01-10-2013, 11:04 PM   #11
jocko
jocko's Avatar
ha, good luck with that... I'd settle for half of that.
Old 01-11-2013, 02:46 PM   #12
SS Tim
SS Tim's Avatar
With TH200R4 you should be close.
SS Tim is offline   Reply With Quote
Old 01-11-2013, 02:43 PM   #13
SS Tim
SS Tim's Avatar
Close to the source but it is not an exterior color. Here is the back side of the Ditzler color chart and it shows the interior color codes for the trim based on the trim code.
http://www.tcpglobal.com/autocolorlibrary/default.aspx
If the code is 622-623-624-625 then it is Dark Sandalwood and the column paint code is Ditzler 23374
Old 01-11-2013, 04:02 PM   #14
Longhorn 70
While stumbling around for the paint I found automotive touchup. They sell touch up paint by paint codes for MANY cars including our trucks.
Just wanted to share the info.
Has anyone bought from them before and what were the results???
