01-09-2013, 06:34 PM | #1 |
Quadrajet question
Hey Guys, I'm a neophyte when it comes to carburetors. I am renovating a 1974 GMC C1500 pickup. I'm putting a new stock 350 from Summit in it. A friend gave me a quadrajet 17083226 3202 FKC. It is for an 81-86 Chev/GMC/Truck BOP. It has the electric choke. Can I use this on my truck? Don't laugh too hard if I'm out in left field just educate me a little please. Thanks!
01-09-2013, 07:02 PM | #2 |
Re: Quadrajet question
It will work just fine. Run a hot wire to it that is only hot when the ignition is on, and then it will work as long as it is adjusted properly. If you have an air choke, you'll have to make provisions to block off the port at the manifold. Other than that, you should be fine. It will bolt right up.
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 |
01-09-2013, 07:21 PM | #3 |
Trash.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
01-10-2013, 10:38 AM | #4 |
Just here to tinker
He asked if it will work, not your opinion. If you have no helpful input for the OP, do not post at all.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
01-09-2013, 07:49 PM | #5 |
My quadrajet is acting up. I've had a few on some of the Fbody cars I've had. After a rebuild from someone that knows what they are doing they are fine. But, if you dont know anyone that is good with them, get something different. I've always had luck with edelbrocks. I think that is what I'm going to have to do here next week.
01-09-2013, 08:42 PM | #6 |
Assuming the carb looks in decent shape, just get a stock GM manifold (non-egr unless you have to worry about emissions) and give it a try. The GM manifold won't need any adapters and should be cheap to get from a salvage yard. If the carb works at all, it should get you through the rest of the restoration project. Once you get the rest of the truck fixed up, then you can always re-think the carb and manifold question. Until then, save your money.
01-09-2013, 08:56 PM | #7 | |
I went with this qjet from summit http://www.summitracing.com/parts/JET-36001
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
01-09-2013, 09:09 PM | #8 |
the q-jet is a great carb, it will give you the best balance of economy and performance. if the fuel was drained and it was stored properly, chances are you can just throw it on and go. cliff's high performance sells a great kit for 35 bucks to go through the carb if you need to tear into it...don't be afraid of the q-jet, most people don't like them because they have more parts than most carbs.
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
01-09-2013, 10:37 PM | #9 |
ive been told a q-jet is great and doesnt need constant adjustment like a holley.
But beware that they have a cork float that after time will get saturated and sag causing you to waste 30 to 60% of fuel. They are also known for " quadro bog " but if you can find somone to adjust your butterflies they are dependable. |
01-10-2013, 01:55 AM | #10 | |
Tyler ------------------------------------------------------ 1980 2wd blazer 1985 k10 diesel truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=652276 1987 wrangler 4x4 build-http://67-72chevytrucks.com/vboard/s...d.php?t=663784 |
03-28-2013, 09:16 PM | #11 |
I do have a mechanic friend very familiar with the quadrajet. He has rebuilt it for me and I have it mounted on the new engine.
03-29-2013, 10:58 AM | #12 |
I think you will love it if it has a good rebuild and tuned correctly. As said before it has the best economy/ performance out there for a carb. I get better milage with my Qjet than most people do with their fuel injections on similar set ups.
Dan 83 Chevy K10 Scottsdale, ZZ4, TH700r4, 4.10, 33" |
