Old 01-11-2013, 06:16 PM   #1
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Shift Linkage help...
Trying to find a solution for the shift linkage/cable for my set up...
PB DM, with a 5.3/4l60e combo - 77SWB.
What are you guys typically running? It seems the lokar shift linkage kit won't clear the firewall due to the motor being raised, and the lokar cable kit is just an odd fit causing one of the brackets to hit the brake booster
Do I need to make my own linkage?
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 01-15-2013, 03:14 PM   #2
solidaxel
solidaxel's Avatar
Re: Shift Linkage help...
Question, why can you not use the stock location and linkage and not a cable
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-15-2013, 03:45 PM   #3
JNJchev77
Registered Cruiser
JNJchev77's Avatar
The stock location should work, and possibly the stock cable, but I don't have the stock cable. It was trashed when I bought the truck.
The cable I have is from Lokar, and it would work, but the brackets they use cause interference with my brake booster (Smaller brake booster). And the cable comes up by the driver's tire, where my tubs will be going. I'm just not satisfied with the look of it...
I found the lokar linkage (rod), not cable, and will try that out when it gets here. Sounds like that is what some guys are using.
77' Chevy SB
5.3/4l60e combo
Old 01-16-2013, 08:45 PM   #4
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
I'm using the lokar linkage, works fine for me.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 01-17-2013, 10:35 AM   #5
solidaxel
solidaxel's Avatar
Is the linkage a solid rod or cable?
LS 3 4L70E
Old 01-17-2013, 11:50 AM   #6
JNJchev77
Registered Cruiser
JNJchev77's Avatar
It's a solid rod, stainless steel.
77' Chevy SB
5.3/4l60e combo
Old 01-18-2013, 09:43 PM   #7
usmcchevy
usmcchevy's Avatar
Yep, I think the part number is aca-1800
Build thread
LSx Swap FAQ index
Old 01-18-2013, 11:01 PM   #8
mooseknuckles
mooseknuckles's Avatar
me too...had to bend it a little but works awesome...
mooseknuckles is offline   Reply With Quote
Old 01-19-2013, 02:00 AM   #9
harnalien
TruckincrazY
harnalien's Avatar
Ditto
My build thread - '84 2wd w/ a 6.0 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=433595
harnalien is offline   Reply With Quote
Old 01-20-2013, 06:17 PM   #10
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Yep, installed it yesterday, works perfect. Great piece imo! Thanks for the help Moose!!
77' Chevy SB
5.3/4l60e combo
Old 01-20-2013, 07:45 PM   #11
mooseknuckles
no prob man...
Old 01-20-2013, 09:09 PM   #12
BigShoe24
True Addiction
BigShoe24's Avatar
Could you upload a picture? Thanks,
RCC
BigShoe24 is offline   Reply With Quote
Old 01-20-2013, 11:06 PM   #13
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Hope this helps... Pretty straight forward install.
77' Chevy SB
5.3/4l60e combo
Old 02-28-2013, 10:40 PM   #14
BigShoe24
True Addiction
BigShoe24's Avatar
I was hoping this would work from me but it appears it is unlikely a rod is going to work; just not enough room. Has anyone tried the Lokar column cable shift linkage? I wasn't 100% sure if the brackets would work on the steering column.
Thanks,
RCC
Old 03-01-2013, 04:49 PM   #15
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
This is where floor shifters make life easy.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
