temp wire location help
Hey guys trying to find the wire that goes to the temp sender on the block on my 75 k20. I had put an aftermarket gauge on my truck but would now like to hook up the original gauge in the dash. I grabbed a wire with connetor from the junk yard but I cant locate my wire on my truck. I have traced them all from the fuse block and cant seem to find it. Everything I read says green wire but my dark green wire goes to my starter. Can anyone help or tell me where to look for this wire?
Re: temp wire location help
Wow the green wire is all I know, if its not spliced and goes to the bulk head on the firewall, I don't know. If its spliced, look for the green wire at the bulk head, might be cut inside the harness.
Another way, if you have any open wires, first make sure they are not a 12 volt positive wire. Then with the key on, touch the suspect wire to metal and see if the gauge maxes out. Posted via Mobile Device
2004 Silverado Crewcab 1972 Chevy Monte Carlo 2017 Chevy Tahoe |
Yea I had the wire orginally and I dont see it cut anywhere. I have been looking all over for an open wire on the druvers side I have a green one coming from the pass side but I know its from the driver side. Does anyone have a oic of where it comes from on the bulk head?
#4 | |
Moderator
![]() Join Date: Oct 2008
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
I have no idea where this wire is, I have traced evry wire down and I cant find an open one at all. I guess I will just have to tap into it in the cab. I cant get the wiring diagrams to load correctly so is the temp wire green in the cab also? Thanks
Moderator
You'll need to download the PDF to a local directory on your PC then open it in the Acrobat Reader. The PDF files will not reliably open directly from the web in Acrobat Reader (this is on purpose). The files open when downloaded to a local virtual drive on my Windows 2000 VM-Ware image using the very outdated Acrobat Reader 6 ( I just tried it ) so they should work with any later Acrobat versions.
I attached a JPG crop of just the bulkhead plugs. TEMP is CIRCUIT#35. TEMP wire on the engine compartment side is DARK GREEN. Cab side is DARK GREEN as well. NOTE: There are two TEMP wires in the cab. 35A goes to the Ignition Switch and 35B goes to the Instrument Cluster. ![]()
