rim offset and backspacing
hi i got a 70 c10 lowered 2/4. i wana run 20 inch wheels all way around. id like to run 20x8 in front and 20x10 in the rear. how much offset/backspacing do i need to keep the wheels tucked inside the wheel wells without hitting anything. any advice much apreciated.
Re: rim offset and backspacing
5.5" bs in rear and 4.75" bs with an 8" wheel in the front. More common you'll find an 8.5" with a 10" rear and then would run 5.25" bs. Many factors will change an offset and its best to measure for your application. These numbers are what most run though
Scott 67 c10 sold 89 c1500 90 k2500 91 s10 #chevyonly ![]() |
backspacing your just measuring from the middle of the rim on the backside to the wheel well/or frame rail? what are you basing the measurments from?
67-72 parts collector,…
![]() Join Date: Nov 2002
Here you go,...
Read, read, read,...
http://67-72chevytrucks.com/vboard/s...d.php?t=442104
Good thread with videos,...
http://67-72chevytrucks.com/vboard/s...ht=backspacing
